Help - FSB Overclock = Very Low FPS
abnospam
22
Hi all,
Well, I am new to this, but I got my FSB overclocked to 400mhz (8x) with DDR-800 memory @ 400mhz 5-5-5-15. I have a e6750 and a Asus p5k-e. All looks good and stable and I literally only changed the FSB speed, set the DDR speed and gave my memory 1.9v per G.Skill.
Well, I thought it was a success with temps topping out @ 35c. Today I download Call of Duty 4 demo and try to play it with my 8800GT. Frame rates are like 8. It is unplayable. I go back to the bios, reset everything to auto and the frame rates are up to 70!
What did I miss? Why is my fps so bad?
Yes, I run orthos and many sandra benchmarks. It is very stable. Many folks have overclocked a similar setup with same MB and CPU to twice as high as I have. I am playing it safe at this level. Seems very stable. But why is my PCIe card not behaving?
Did you lock the PCIe frequency to 100MHz?
Just to make sure, you ran Orthos blend test for 8hours and found it stable?
If so, what is your PSU? The symptoms you are experiencing is very like a system not getting enough power.
I ran orthos for about 2 hours. (I know I should go more, but I figured if there is a Toms article OC'ing this setup to 440, I should be in the clear).
The PSU is an Antec 500 watt, 18a on 2-12v rails. ( I plugged one 6-pin connector into the 8800GT as I assume pulling from both rails happens automatically?). The card wants like 26 amps or something.
The game lag is immediately, within 3 seconds of the game starting and it is at 8 fps.
appreciate the help.
Although people will tell you your PSU is fine, but I think otherwise.
Symptoms of not enough power is usually crashing during any intense load or stuttering during intense gaming.
I suggest you to get a quality 550W PSU, but I recommend the Corsair 620W PSU.
Yes, that PSU should be enough, however there is that possibility it isn't. Perhaps it's defective?
Anyways stress test your RAM. This is called blend test.
That is difficult without the proper tools and devices. As I said before, if it starts crashing and stuttering during games for no reason, it's probably the PSU. Before that, make sure you have ran Orthos small FFT's for 6 hours and blend test for 8 hours.
Not necessarily. Perhaps you PSU can only really do 300W or something.
That's a good PSU, so really, it should be fine.
if your gfx card is not getting enuf juice then it has a speaker on it and screams at you, 500w is enough anyway, is it only cod4 its slow on? you need to oc and then find out what ure pcie bus width is when you oc and also what your gfx card settings are, because sometimes its doesnt work and sets it up wrong at say 1xpcie instead of 16 or the gfx card settings the core will drop down to 400mhz and mem to 600 if all of that is fine then you can check with other games and it might be a driver isue.
