ha, i guess u could say that
😛... but we are close! im gonna catch u soon... and by the way u kinda messed up with getting the x850pro too
😛 considering its just an overclocked x800 (overclocked by like 50 mhz?) but whatever it prob runs all ur games fine with no aa and af... by the way u cant say clawhammer is "bad" its just not the best amd core to be released, they are by no means bad, ur fx55 will run just as fast as the san diego one, but a bit hotter, there kinda like the prescotts of amd (except they dont suck
)... but anyway, i duno where u like to shop, online, retail whatever... but this is the cooler i was thinking of
http://www.compusa.com/products/product_info.asp?product_code=335987&pfp=SEARCH its actually a 92 mm fan, but its still pretty damn good. if u really need the 120mm (which u just may) the fatality one will be good enough to keep that chip cool, i duno if zalman makes a 120mm that isnt fatility, but if u find 1 get that instead, with the fatality ur paying about 10 more for the name...
http://www.compusa.com/products/product_info.asp?product_code=335815&pfp=SEARCH i bet u can get to the low 40's idle with that heatsink... if u buy that and find that its not enough cooling, get watercooling... it WILL keep that chip in the low 40's... id say try the fatality first (or a regular 120mm zalman) anyways, goodluck, and tell me how it works because i have the same problem (although im not as worried about it) with my 3700, idle is 49, full load is high 60's... so u arnt the only 1 with this problem...
