G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
I just got done doing a cap kit (my first one ever)on a G07 19".
Before i took the chassis off the frame there is a black wire that is
connected to the tube and looks like a ground strap.
This wire is not the degaussing coil.
i just need to know where the wire hooks in to. I believe is it on the
neck board from the schmatics but where on the neck board i have no
idea.
if someone has a pic of this or can help i would be really
appreciative.
Also i was wondering, i did not do the sync mod, should i do it or just
wait to see if i have a horizontal curl.
Lastly, i heard that the G07's like a composite sync should i use the
jumper on the negative sync for ms pac man or not.
thanks in advance (tia),
this group is awesome they have helped me very much and i have enjoyed
collecting and fixing up some classics over the past year.
Frank
my current collection:
track and field cocktail, ms pac cocktail, Galaga UR.
Summer projects to finish:
Star wars UR, Multi Williams UR, Double Donkey Kong UR.
idea.
appreciative.
Frank
