So, this all started about 7 months ago when I got my new PC.
About a month later, I started noticing lag on a lot of my games.
It got worse. Now, Rocket League is always dropping FPS, It'll go from 250, to 140. I have a 120 hz monitor, so I shouldn't be able to see it. But I definately can. The ball feels like it's moving slow, it's just very weird. The more cars there are, the more frame drops I get. 1s isn't that bad, 2s is pretty bad, 3s is almost unplayable. When I close Rocket League, I hear crackling too.
H1Z1 lag is different. It's frame stutters. Every time I try to play the game, randomly my I will get frame stutter. Sometimes it's every 30 seconds, sometimes it's every 10 mins, it's random. This lag is my screen freezing for about a second, and making a crackling sound.
The culling has the same problem as h1. I have almost 40 hours on the game now. My FPS will go from 62 to 59-58ish, and i'll feel the game get slower. The game has done the same kind of drops I get on H1 randomly. Where my screen freezes for a second. That's only happened twice on the culling. It happens a lot more often on H1.
My main concern here is Rocket League, as I play the game competitively.
Attempts to fix:
BOUGHT ALL NEW PARTS - Well, not all new parts. I bought a new processor (i7 4790K), new graphics card (GTX 980) new ram (2x8GB Corsair vengence ram) new mobo (Asus z97 mobo) and finally new SSD (HyperX 120GB SSD+New windows) I installed the new windows on the new SSD, booted it up, installed the new drivers, and chrome, steam, and Rocket League. SAME LAG. I don't get it.... It makes no sense to me. The only parts I haven't replaced are my PSU, and 2TB HDD.
After those new parts didn't fix, I returned them and got even newer, upgraded parts. i7 6700K Corsair DDR4 ram, Z170A mobo, new case, fans, new psu. 850W corsair.
Still getting the same lag.
I've unplugged my HDD while gaming to see if that was the issue, same drops drops/stutters.
Tried disabling sound drivers, same drops drops/stutters.
Turning vsync on and off, same frame drops.
Changing settings in nvidia control panel, same frame drops.
Yes, i've made sure my monitor was plugged in to my GFX card. (Not completely stupid, only a little 😀)
All of my temps are completely normal while gaming. No CPU spikes when it happens, no ram spikes when it happens.
I already tried deleting Geforce Experience while gaming, same issue.
So as you can see, i've tried almost everything. I don't get where this lag is coming from. After replacing basically my whole computer. I still don't know where the frame drops, stutters, and all of that is coming from. I'm extremely frustrated. The last week has been me just trying to fix this. and it's still not fixed.
However, I did finally switch the outlet that my PC was plugged in to. It fixed it a little bit. Games are a lot smoother. I thought it was a power problem. So I went out and purchased a cyperpower UPS with Sinewave. Plugged that in and it was working a lot better. But the lag is still there. Not nearly as bad as it use to be. But still VERY VERY annoying. Pls help. 🙁
Would be very grateful if you fix this.
Attempts to fix:
