Hi,
I have 4 sticks of GSkill 2400 DDR3, 2 are same model and the other two of a different model, but same brand. I can't get them to work in my AMD FX8350 system @ 1866Mhz, I know these DIMMs are of the wrong (higher) speed, and currently they can run at 1600Mhz, but when I try to push them to 1866Mhz, the BIOS won't post. Looking at the SPD table in CPU-Z, the RAM sticks don't have a 933Mhz setting, is this the reason?
I also tried to manually set the timings along with the RAM clock to 933Mhz, but no luck. Any suggestion what timing I should set?
Or by the way, if I only put two sticks in, it works flawlessly at 1866Mhz!
And, the SPD table for two types of sticks have:
685, 761, 800, 1200Mhz (XMP)
The other has:
761,800, 1200Mhz (XMP1), 1200MHz (XMP2)
Since they are so different, and without a 933Mhz, is it necessary to reprogram the SPD of the DIMM in order to get it work? ie, using tool such as Taiphoon?
And, my MB and CPU are all supposed to support 4x4G at 1866Mhz from what I've read.
Some details about my setup:
MB: Gigabyte GA-970A-DS3P BIOS ver: FD
CPU: AMD FX 8350
GPU: Gigabyte GTX1060 3G
Memory: 2 sticks of G.Skill Sniper F3-2400C11D-8GSR, DDR3-2400, CL-11-13-13-31 1.65V, PC3-19200 4Gx2 Intel XMP Ready
2 sticks of G.Skill Trident X F3-2400C10D-8GTX, DDR3-2400 CL10-12-12-31 1.65V, PC3-19200 4Gx2 Intel XMP Ready
Thank you for your help!
The other has:
CPU: AMD FX 8350
