HELP GFX compatibility with msi h81m-p33 Motherboard.
EmpSkyblade
9
I bought a MSI R9 380 GAMING 4G on amazon, but i forgot to check if it was compatible with my motherboard (msi h81m-p33 ) as i was concentrated on checking a PSU for it. i need to know if it is compatible.
Your Motherboard has a PCIe x16 slot so your GPU will work. Have a nice day building your PC, btw what PSU do you have? I would suggest a good 500-550W psu from corsair/seasonic series
im buying 600 w from evga
probably
If its 600b then dont go for it, instead for under 50$ get this http://pcpartpicker.com/part/xfx-power-supply-p1550sxxb9
XFX 550W PSU, its made by Seasonic and sold by XFX so i can tell its a good one. Its a rebranded Seasonic S12II 520 with more wattage :)
i got kind of a problem, you see i dont live in united states, so when i buy stuff overseas shipping cost depends on weigth, a power supplys weigth a ton, i was buying the evga one because it was in stock on a local shop.
There was also a coolermaster elite v2 for 59.90
Where do you live? And dont go for Coolermaster Cpu's they are bad.
i live on Panama
