Help Gpu 6pin Problem
zxcXtian
Hi, Im just new here in tom's.
Just want some help. My gtx 560 needed 2 6-pin power connector. But as soon as i insert 2 connectors. My pc wont power up. Fans just spin for half second then power off. Tried inserting only 1 connector. Inserted it in the left side 6pin slot (tried both 6 pin connectors). Pc powers on. Tried on the right 6 pin slot then dont power on.
Could it be a gpu problem?
Do you perchance have another pci-e slot on your mobo? If so move it to that and try connecting both 6 pin plugs in. If that doesn't work then you may have a dead card on your hands. If it does work then that pci-e slot has gone bad
Proc: i5-3330 Biostar mobo, 8gb ram, and 500gb wd 7200 hdd, Korean Psu 600w truerated (I know its crappy but its all i can afford right now. Planning to upgrade psu)
