Specs:
OS: Most Recent windows 10 update
CPU: i5-4590 (yes i get low temps with hyper evo 212)
GPU: MSI 1060 6 GB Gaming X
Ram: Ballistix Sport 8GB
Mobo: MSI Intel z97 PC Mate
HDD: 2 TB Seagate
PSU: EVGA 500w
Monitor: Generic 1080p 60fps Acer
Net speed (just in case): 25mbps download 2mbps upload with only 2-4 devices including pc on the network. I also have sometimes google or Skype or sometimes both running in the background and haven't recorded for YouTube in a while although I sometimes do.
Games I play:
Grand Theft Auto 5
Rust
Gears of War 4
Forza Horizon 3
Wildlands
For Honor
DayZ
Skyrim
Fallout 4
Civ 6
Outlast 2
(etc.)
My Problem:
I get bad fps drops and even audio lag but rarely I don't know why. To my limited knowledge I have a relatively decent pc. It isn't watercooled, and doesn't contain 20 $5,000 graphics cards and led lighting up my neighborhood streaming to 5 8k monitors at 600 fps but it gets the job done.
It kind of started around when I gave half of my Ram away (when I had 16 GB now I have 8 GB like stated in the specs) to a friend in a build I made for him but that could be coincidental. There are no viruses and I have clean installed windows multiple times with still lag every time. I sometimes use settings that I see on youtube videos of people with similar pc setups recommending the max out the game or a little more but I sometimes have rendering problems like when a gears match first starts its really laggy cause i feel it may still be rendering things in and in gta 5 I randomly drop to like 4 frames or something and my gaming experience is just horrible a 1060 ^ GB should be able to max out gta and get above 60 and some people are but I don't know how to figure out my source of the problem :/ It's seems like I played better on my 960 4 GB that I gave away at similar settings too. The first 1060 I got from amazon had a fan that didn't spin half the time but I believe and really hope this 1060 is good as at least the fans work.
Anyone have any ideas? I was thinking Ram possible and yes its registers as 8 GB still in my pc info but is there a way it could be a little faulty or is there anything you guys can help me do to figure out why I get frame drops?
Uningine Test:
So I tried recording my fps drops but it didnt work so well, my upload speed is trash and I lost power while uploading the video.
I decided to get Uningine and test my fps there. Keep in mind I have a good system and when other people with similar setups while recording tested there min frames was around 30 but mine dropped to 7 just like my games do I will put log files below.
05:03:52 Loading "C:/Program Files (x86)/Unigine/Heaven Benchmark 4.0/bin/../data/heaven_4.0.cfg"...
05:03:52 Loading "GPUMonitor_x86.dll"...
05:03:53 Loading "dxgi.dll"...
05:03:54 Loading "openal32.dll"...
05:03:55 Set 1920x1080 fullscreen video mode
05:04:00 Set 1.00 gamma value
05:04:00 Unigine engine http://unigine.com/
05:04:00 Binary: Windows 32bit Visual C++ 1600 Release Feb 13 2013 r11284
05:04:00 Features: OpenGL Direct3D9 Direct3D11 OpenAL XAudio2 XPad360 Joystick Flash Editor
05:04:00 App path: C:/Program Files (x86)/Unigine/Heaven Benchmark 4.0/bin/
05:04:00 Data path: C:/Program Files (x86)/Unigine/Heaven Benchmark 4.0/data/
05:04:00 Save path: C:/Users/mjlga/Heaven/
05:04:00
05:04:00 ---- System ----
05:04:00 System: Windows NT 6.2 (build 9200) 64bit
05:04:00 CPU: Intel(R) Core(TM) i5-4590 CPU @ 3.30GHz 3299MHz MMX SSE SSE2 SSE3 SSSE3 SSE41 SSE42 AVX HTT x4
05:04:00 GPU: NVIDIA GeForce GTX 1060 6GB 22.21.13.8205 x1
05:04:00 System memory: 2047 MB
05:04:00 Video memory: 4095 MB
05:04:00 Sync threads: 3
05:04:00 Async threads: 4
05:04:00
05:04:00 ---- MathLib ----
05:04:00 Set SSE2 simd processor
05:04:00
05:04:00 ---- Sound ----
05:04:00 Renderer: OpenAL Soft
05:04:00 OpenAL vendor: OpenAL Community
05:04:00 OpenAL renderer: OpenAL Soft
05:04:00 OpenAL version: 1.1 ALSOFT 1.14
05:04:00 Found AL_EXT_LINEAR_DISTANCE
05:04:00 Found AL_EXT_OFFSET
05:04:00 Found ALC_EXT_EFX
05:04:00 Found EFX Filter
05:04:00 Found EFX Reverb
05:04:00 Found EAX Reverb
05:04:00 Found QUAD16 format
05:04:00 Found 51CHN16 format
05:04:00 Found 61CHN16 format
05:04:00 Found 71CHN16 format
05:04:00 Maximum sources: 256
05:04:00 Maximum effect slots: 4
05:04:00 Maximum auxiliary sends: 2
05:04:00
05:04:00 ---- Render ----
05:04:00 D3D11Render:😀3D11Render(): Unknown NVidia GPU
05:04:00 Direct3D11 desc: NVIDIA GeForce GTX 1060 6GB
05:04:00 Found feature level 11.0
05:04:00 Found compute shader 11.0
05:04:00 Maximum texture size: 16384
05:04:00 Maximum texture units: 16
05:04:00 Maximum texture renders: 8
05:04:00
05:04:00 ---- Physics ----
05:04:00 Physics: Multi-threaded
05:04:00
05:04:00 ---- PathFind ----
05:04:00 PathFind: Multi-threaded
05:04:00
05:04:00 ---- Interpreter ----
05:04:00 Version: 2.52
05:04:00
05:04:00 Loading "heaven/unigine.cpp" 56ms
05:04:00 Unigine~# render_restart
05:04:00 Loading "heaven/locale/unigine.en" dictionary
05:04:00 Loading "core/materials/default/unigine_post.mat" 23 materials 50 shaders 7ms
05:04:00 Loading "core/materials/default/unigine_render.mat" 47 materials 2368 shaders 8ms
05:04:00 Loading "core/materials/default/unigine_mesh.mat" 5 materials 3386 shaders 38ms
05:04:00 Loading "core/materials/default/unigine_mesh_lut.mat" 2 materials 1062 shaders 2ms
05:04:00 Loading "core/materials/default/unigine_mesh_paint.mat" 2 materials 1158 shaders 26ms
05:04:00 Loading "core/materials/default/unigine_mesh_tessellation.mat" 5 materials 3332 shaders 9ms
05:04:00 Loading "core/materials/default/unigine_mesh_tessellation_paint.mat" 2 materials 2276 shaders 5ms
05:04:00 Loading "core/materials/default/unigine_mesh_triplanar.mat" 1 material 112 shaders 1ms
05:04:00 Loading "core/materials/default/unigine_mesh_overlap.mat" 1 material 300 shaders 2ms
05:04:00 Loading "core/materials/default/unigine_mesh_terrain.mat" 1 material 813 shaders 2ms
05:04:00 Loading "core/materials/default/unigine_mesh_layer.mat" 1 material 84 shaders 1ms
05:04:00 Loading "core/materials/default/unigine_mesh_noise.mat" 1 material 106 shaders 2ms
05:04:00 Loading "core/materials/default/unigine_mesh_stem.mat" 2 materials 2180 shaders 12ms
05:04:00 Loading "core/materials/default/unigine_mesh_wire.mat" 1 material 45 shaders 0ms
05:04:00 Loading "core/materials/default/unigine_terrain.mat" 1 material 1980 shaders 4ms
05:04:00 Loading "core/materials/default/unigine_grass.mat" 2 materials 474 shaders 4ms
05:04:00 Loading "core/materials/default/unigine_particles.mat" 1 material 109 shaders 1ms
05:04:00 Loading "core/materials/default/unigine_billboard.mat" 1 material 51 shaders 1ms
05:04:00 Loading "core/materials/default/unigine_billboards.mat" 2 materials 840 shaders 3ms
05:04:00 Loading "core/materials/default/unigine_volume.mat" 6 materials 53 shaders 5ms
05:04:00 Loading "core/materials/default/unigine_gui.mat" 1 material 82 shaders 0ms
05:04:00 Loading "core/materials/default/unigine_water.mat" 1 material 533 shaders 49ms
05:04:01 Loading "core/materials/default/unigine_sky.mat" 1 material 21 shaders 18ms
05:04:01 Loading "core/materials/default/unigine_decal.mat" 1 material 99 shaders 0ms
05:04:01 Loading "core/properties/unigine.prop" 2 properties 0ms
05:04:01 Unigine Heaven Benchmark 4.0 (4.0)
05:04:01 Unigine~# world_load heaven/heaven
05:04:01 Loading "heaven/heaven.cpp" 125ms
05:04:01 Loading "heaven/materials/heaven_base.mat" 7 materials 53ms
05:04:02 Loading "heaven/materials/heaven_environment.mat" 13 materials 1141ms
05:04:06 Loading "heaven/materials/heaven_ruins.mat" 27 materials 3735ms
05:04:10 Loading "heaven/materials/heaven_buildings.mat" 58 materials 3898ms
05:04:11 Loading "heaven/materials/heaven_props.mat" 10 materials 1028ms
05:04:11 Loading "heaven/materials/heaven_sfx.mat" 11 materials 7ms
05:04:14 Loading "heaven/materials/heaven_fort.mat" 15 materials 2498ms
05:04:19 Loading "heaven/materials/heaven_airship.mat" 26 materials 5164ms
05:04:24 Loading "heaven/heaven.world" 22417ms
05:05:13 Unigine~# video_restart mode
05:05:13 Set 1920x1080 fullscreen video mode
05:06:26 Benchmark running
05:10:48 Benchmark results:
05:10:48 Time: 260.51
05:10:48 Frames: 11428
05:10:48 FPS: 43.8679
05:10:48 Min FPS: 7.69235
05:10:48 Max FPS: 63.7502
05:10:48 Score: 1105.03
05:11:21 Unigine::Benchmark::save_result(): can't create "C:/Unigine_Heaven_Benchmark_4.0_20170506_0511.html" file
05:11:48 Unigine~# quit
05:11:53 Close "openal32.dll"
05:11:53 Close "dxgi.dll"
05:11:53 Memory usage: none
05:11:53 Allocations: none
05:11:53 Shutdown
HDD: 2 TB Seagate
PSU: EVGA 500w
Games I play:
Grand Theft Auto 5
Rust
Gears of War 4
Forza Horizon 3
Wildlands
For Honor
DayZ
Skyrim
Fallout 4
Civ 6
Outlast 2
(etc.)
My Problem:
Uningine Test:
05:04:00
05:04:00
05:04:00
05:04:00
05:04:00
05:04:00
05:04:00
05:04:00
05:11:53 Shutdown
