[HELP] GPU Upgrade
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Good day,
I would like to ask some recommendation(s) in changing the GPU.
I have some ideas but I don't know about bottlenecks and compatibility thus I'm asking for expert opinions.
I mainly use this for gaming but the current games are somewhat unplayable.
I highly doubt I would have a long list of recommend GPU upgrades so let's not worry about the budget and there's also the bottleneck and compatibility to consider.
Looking for the very last GPU I can upgrade to.
Thank you advance for reading and helping.
CPU: AMD A6-3670 APU
RAM: 8Gb
MoBo: Gigabyte GA-A75M-DS2
GPU: AMD Radeon HD 6670
Oh sorry forgot to mention the purpose.
I'm using my PC mainly for gaming.
I know my current build is not what you call high end but I'm looking to upgrade my GPU so I can play the latest games.
Maybe fallout 4, xcom 2, Witcher 3 and others.
About the budget, I doubt I would have a long list of recommended GPU for my current PC.
As long the there's no problem in the bottleneck and compatibility department then we go with that.
Might build a new PC 2 or 3years from now when I move to the new house.
@unksol
What do mean you wont recommend it?
How do I remove a post and best solution?
This is my first time posting in here so I'm lacking in some common sense on how to use and edit this thread properly.
Thanks for removing the best answer(^,^)V
How about the Sapphire AMD R9 980X Nitro?
that card is amazing but you will be held back by the power of your processor.....the best/most powerful gpu you can get and not cause a bottleneck is the 750ti or r9 270 which is a little more expensive......if you plan to upgrade the cpu/mobo wihitn a year id say get the best card you can afford and let us know the budget you have
