Help.... Gta v lagging due to low cpu utilization
Abstergo
Commendable
Sep 19, 2016
8
Hey guys
I love playing games on pc but i dont have a high performance pc.. I played gta V on the same pc before without any lag but im facing some issues.
I have intel Pentium g2030 and intel hd graphics and when i launch gta v the game runs on 30+ fps and then after a while the game starts to lag to the point where it is unplayable... It can be noticed especially while driving.. So i opened up task manager and saw the performance....when i launch the game, cpu utilization is greater than 75% thats i get more performance at first then it backs down to below 60% and then the game starts to lag.
Anyone help me ! How get full cpu performance?!
Note- the integrated graphics performance is fine, the problem is with cpu
Thanks
CPU utilization will be less than 100% if your GPU is struggling. Integrated graphics are not appropriate for gaming with high framerates. If you add a discrete GPU, your problems will go away.
dude intergrated graphics is not good for gta v ...i was using i5 4460 with the intel hd graphics and could barly get 30fps on lowest ...plus your cpu is dual core and this game needs qaud
@Helpstar... Cpu is not overheating and im sure CPU temp stays down 40c
@danny_51... I agree that integrated graphics suck but the game lags even at lowest settings i mean it works on 30+ fps for the first few minutes and i have seen gta v run on dual core cpu smoothly and i ran it fine before
I don't think you quite grasp the severity of how bad integrated graphics suck. I also have an i5 4460, and it's bad.
First you are bound by having a dual core CPU that also runs incredibly slowly. I know Science Studio ran GTA5 on 2 cores, but that's 4.4ghz 2 cores with 8mb L3 cache per core, not 1.5mb. Also, he had a GTX 980ti, not integrated graphics. For comparison, I can't even run league of legends at the lowest settings at 1280x720 at 30fps on integrated graphics. How can you expect GTA5 to function any better on a CPU with less than half the performance?
Please, set your expectations straight.
@amtseung... I played gta v on the same pc before on 800*600 res... Thats why i asked
@Helpstar... Bro i first thought it was cpu throttling and i disabled cpu halt in bios.. It locked CPU on highest clock speed but CPU utilization was still dropping
