Help! GTX 560 2GB Less Than 30 FPS in Minecraft
FB1Productions
13
I have a GTX 560 2GB OC with a i5 3570K @ 4.2Ghz
but in minecraft I only get 24 FPS. It seems like it's locked at 24 FPS. It only gets locked at 24 FPS when I go 1920x1080. When I pull the minecraft window as high as it can get and about 1 inch from the side of the screen on each side (27" diagonal monitor) I am still at 400 FPS as it was when it was smaller. But when I pull it those inches on each side my FPS drops to 24 and stays locked there.This issue isn't due to switching to the integrated graphics because my GPU usage goes up. This has just recently randomly begun to occur. Anyone know a solution?
www.minecraftforum.net/topic/939149-launcher-magic-launcher-098-mods-options-news/
Get the minecraft magic launcher and attribute more ram to minecraft. Also get the mod optifine nulti-core. It will improve fps, has built in hd texture pack support, you can change many settings, and uses a second core for minecraft.
locking at 24fps seems a good clue!
.........maybe.....either minecraft has a setting that locks fullscreen to 24fps - or - the gfx card's control panel has done this to this game. In either case, check both senarios for an option to prevent fps locking to screen refresh rate or increase the locking target rate. I know that some games have options for this very 'issue'.
Monitor refresh rate(vertical scan) linked to/influencing game fps - yes, that would prove it - try altering your monitor refresh rate and see if the fps alters, if it does, then one of the two options I mentioned above may well be the culprit.
