RonSolid Honorable Jan 5, 2013 2 0 10,510 Jan 6, 2013 #1 Will my emaxx emx-ih61le-icafe MOBO be compatible with a Radeon HD 7870 GPU?? my main concern being the 2 pci-e slots needed to power it
Solution Sunius Jan 6, 2013 Where did you read that you needed two PCIe slots? It need two PCIe connectors from the power supply unit, not the motherboard. Concerning the motherboard, it will work just fine. Make sure you power supply unit is up to the task, though!
Sunius Splendid Dec 19, 2010 9,582 0 31,960 Jan 6, 2013 Solution #2 Where did you read that you needed two PCIe slots? It need two PCIe connectors from the power supply unit, not the motherboard. Concerning the motherboard, it will work just fine. Make sure you power supply unit is up to the task, though! Upvote 0 Downvote Solution
ASHISH65 Splendid Oct 15, 2012 5,964 0 27,310 Jan 6, 2013 #3 It will work.make sure that you have good cpu with hd 7850. Upvote 0 Downvote
RonSolid Honorable Jan 5, 2013 2 0 10,510 Jan 6, 2013 #4 Best answer selected by RonSolid. Upvote 0 Downvote
