HELP HELP PC not starting up
Blastcakegaming
42
I checked all the power connectors, power button and it wont start. The only thing I'm worried about is the power connector to the motherboard doesn't click into place on one side.
Specs:
Mobo: Asrock 907M PRO3
CPU: FX 6300
GPU: Sapphire r9 280
PSU: Corsair Cx500
HDD: WD BLUE
Case: Zalman Z11 Plus
first things first, have you checked all the psu cables are installed correctly (24 pin, cpu, gpu)? If all that is fine, quickly check to see if your PSU is working, you can do this by following the steps in this video:https://www.youtube.com/watch?v=5FWXgQSokF4
