The motherboard M.2 slot #1 shares bandwidth with a SATA 6.0 Gb/s port. When the M.2 slot is populated, one SATA 6.0 Gb/s port is disabled.
The motherboard M.2 slot #3 shares bandwidth with SATA 6.0 Gb/s ports. When the M.2 slot is populated, two SATA 6.0 Gb/s ports are disabled.
Is there something wrong with the hdd or the sata on the motherboard? How do I fix this? I don't know which is disabled and which one isn't.
Here is my build:
https://pcpartpicker.com/list/jr7HcY
And also got this when I try to boot the pc: Reboot and select a proper Boot Device or Insert Boot Media in selected Boot device <<< What does that mean?
Here is my build:
