Help - How do I setup these in XP Pro ?
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I am using XP Pro. & Outlook Express 6.00.2900...... in my Laptop.
A)
As I right click the 'Start',
Then click 'Properties'
Then click 'Customize' in group 'Start Menu', I get 'Customize Start Menu'.
Under 'General', I have 'Show on Start Menu', with two selections,
As I check in for,
1. Internet - I have one selection, 'Internet Explorer', although I use MSN Explorer also
2. E-mail - I have one selection only , i.e., 'Microsoft Outlook', but I use Outlook Express
as my default E-mail carrier. Is there a way to include or make a change so that I can include
my e-mail as 'Outlook Express', rather than 'Microsoft Outlook'.
B)
How do I setup the Internet Explorer, so that under 'Tools', 'Mail and News', 'Read Mail',
I can open 'Outlook Express' rather than 'Microsoft Outlook', which I don't use at all.
Appreciate suggestions and help.
G
Guest
Guest
A)
1. You say that there is no drop box to select?
2. " " " " " " " " " " ?
B)
The title on the header is Microsoft Outlook Newsreader, it is Outlook Express in /outnews mode. Outlook is not a newsreader, Outlook Express is and that is what you are reading news in.
From your header:
X-Newsreader: Microsoft Outlook Express 6.00.2900.2180
X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2900.2180
Just my 2¢ worth,
Jeff
__________In response to__________
"Okie Noah" <okie_noah@hotmail.com> wrote in message news:%23omZbNK5EHA.1120@TK2MSFTNGP11.phx.gbl...
| A)
| As I check in for,
| B)
G
Guest
Guest
A) Yes I do see the drop box, but with only one selection in each drop box.
I am using the latest Outlook Express 6.00.2900.2180 (xpsp_sp2_rtm.040803-2158)
My home PC does show multiple selections on each drop box.
B) Within Explorer, when I click on 'Read News', it does open 'Microsoft Outlook Newsreader'
But, when I click on 'Read Mail', the 'Microsoft Outlook' opens rather than 'Outlook Express'
|"» mrtee «" <hingelicker$@new.rr.com> wrote in message news:%|23rfRZYK5EHA.2964@TK2MSFTNGP15.phx.gbl...
|A)
|B)
|From your header:
|Just my 2¢ worth,
| Jeff
|"Okie Noah" <okie_noah@hotmail.com> wrote in message news:%|23omZbNK5EHA.1120@TK2MSFTNGP11.phx.gbl...
| A)
| As I check in for,
| B)
G
Guest
Guest
news:u90sDlK5EHA.3504@TK2MSFTNGP12.phx.gbl
> drop box. I am using the latest Outlook Express 6.00.2900.2180
> (xpsp_sp2_rtm.040803-2158) My home PC does show multiple
> 'Microsoft Outlook Newsreader' But, when I click on 'Read Mail',
>> A)
>> B)
>> From your header:
>> Just my 2¢ worth,
>> Jeff
>> A)
>> Menu'.
>> As I check in for,
>> B)
>> I don't use at all.
From http://www.fjsmjs.com/OE/defaultl.htm
Go to Start | Run and type this command, with the double quotes and spaces:
"C:\Program Files\Outlook Express\msimn.exe" /reg
and then make sure that OE is selected as the default mail program in both
IE and OE.
If that isn't enough, see this article:
"Send To" and E-mail Links Do Not Work Using Outlook Express as Default:
http://support.microsoft.com/?kbid=306098
You might also want to try this:
Restores OE to the E-mail clients list in Internet Options
http://www.dougknox.com/xp/scripts_desc/oe_client.htm
To set Outlook as the default mail client,- Go to Start, Run - Type in the
following with quotation marks and press OK
"C:\program files\microsoft office\office\outlook.exe" /checkclient
For more information on Outlook see:
http://www.slipstick.com/config/defaultmailer.htm
Frank Saunders, MS-MVP, IE/OE
Please respond in Newsgroup only. Do not send email
Protect your PC
http://www.microsoft.com/security/protect/
G
Guest
Guest
By setting OE as default mail and news reader
the problem was fixed both in OE and IE.
Thank you so much.
"Frank Saunders, MS-MVP" <franksaunders@mvps.org> wrote in message news:%23f$En3K5EHA.4072@TK2MSFTNGP10.phx.gbl...
| >> A)
| >> B)
| >> From your header:
| >> Just my 2¢ worth,
| >> Jeff
| >> A)
| >> Menu'.
| >> As I check in for,
| >> B)
| >> I don't use at all.
| IE and OE.
| Protect your PC
