Hi, building my first rig on a budget and I don't know what power supply I should get.
Currently, my rig is:
CPU: AMD A6-3500 Llano 2.1GHz (2.4GHz Max Turbo) Socket FM1 65W Triple-Core Desktop APU (CPU + GPU) with DirectX 11 Graphic AMD Radeon HD 6530D AD3500OJGXBOX ~
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103951
MOBO: ASUS F1A75-M LE FM1 AMD A75 (Hudson D3) SATA 6Gb/s USB 3.0 Micro ATX AMD Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131769
Hard Drive: Western Digital WD Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
Optical Drive: LG DVD Burner 24X DVD+R 8X DVD+RW 8X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model GH24NS90
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136247
RAM/Memory: AMD VALUE EDITION 4GB 240-Pin DDR3 1333MHz 4G PC3-10600 CL9-9-9-24 1.5V
http://www.amd.com/us/products/desktop/radeon-memory/Pages/system-memory.aspx#2
http://www.11st.co.kr/product/SellerProductDetail.tmall?method=getSellerProductDetail&prdNo=522130056&service_id=pcdn
(The 2nd site is a S. Korean site if you need details or pictures because apparently they only it sell it here)
CASE: ENERGY OPTIMUS K-2 BLACK TOUCH ATX Mid-tower
http://item.gmarket.co.kr/DetailView/Item.asp?goodscode=334910292&GoodsSale=Y&jaehuid=200002657&service_id=pcdn
(This item is only available in S. Korea, so for more detailed information I provided the site. In case, you can't see it. The power supply mounts on the top, I plan on having approximately 2-3 fans with the case (1x 80mm rear fan, 2x 120mm side fans). There is a front I/O panel with 2x USB 2.0, audio and mic jack, power and reset button)
I tried http://pcpartpicker.com/ but some of the parts aren't listed so it didn't seem very accurate. I plan on using this computer probably till it dies so longevity and reliability is important (something related to PSU efficiency and degradation over time?). I MAY upgrade or add more HDD/SDDs. And it's very unlikely by I MAY also add a discrete graphics card (thinking AMD radeon HD 6670).
SO
1. What is a safe power range for this build? 400? 500?
2. What are some reliable PSU companies/brands?
3. Apparently PSU come with a set number of connectors (ike SATA, 6 pin, and 8 pin PCI E)... how many do I need?
SO
