The green audio jack (speakers out) produces erratic sound quality.
Sometimes the sound is normal, but sometimes it is faint. It goes in and out of these phases intermittently.
I can control the quality of the sound when I move the plug around slightly into the back of the case. It only requires a slight tilt of the plug to produce normal sound.
But whenever I'm gaming, the sound quality is erratic.
Do I need to have the jack replaced, or is there a less expensive way to fix this?
Hopefully I don't have to replace the motherboard?
