Help... how to identify whether I've got a PC100 512MB or ..
steve
2,366
Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
I've got a memory module that was sold to me as a 256MB DRAM, however it's
exhibiting the same behaviour as a previous 512MB module I had purchased -
namely I only see 128MB's of memory. I do however, have a 256MB memory
module in the same machine, so it's hardware does support such a capacity,
simlpy not these chips.
The only thing I can reliably provide are the markings on the chips, it's a
double sided DRAM board - with 9 SAMSUN 043 K4280432B-TC1H chips per side.
It's supposidly a PC100-256MB memory module, Registered ECC memory, but
again, all I see is 128MB, if I install a similar 256MB module from Compaq,
that works fine. (Motherboard is an Asus P2B.. and also I'm trying the same
on a Compaq Proliant 1600).
Any help appreciated,
Regards
Steve
On Mon, 18 Apr 2005 21:48:57 +0900 "Steve"
<news_svaardt@hotmail_NOSPAM_.com> wrote in Message id:
<4263acbe$0$79463$14726298@news.sunsite.dk>:
That motherboard has an Intel BX chipset. Therefore, it only supports 16MB
devices. Look for 256MB DIMMS that have 16 or 18 (if registered) chips on
them.
> them.
Don't you mean "18 if ECC"? Registered has nothign to do with this.
Keith
K4S280432B-TC1H is a 32Mx4 chip. These aren't supported by the 440BX
chipset. Get a 256MB DIMM with 16Mx8 chips.
On Tue, 19 Apr 2005 21:58:23 -0400 keith <krw@att.bizzzz> wrote in Message
>> them.
Yes, my mistake.
