Help...How to test components after surge damage to motherboard
Los Tre
54
Hello guys...I used to have http://www.gigabyte.com/products/product-page.aspx?pid=3798#ov but after a thunder stroke the neighbors electricity tower my pc(and some of the neighbors)got fried from it...My moherboard 100% isnt working cause i unplagged RAM and the beep beep beep wasnt working...Cause i dont have a 2nd pc and test the other items like Card Graphic how i will be able to see if the items still works?
Sorry for my bad english but i'm trying
Unless you have spare parts on hand for testing, you may need to take it to a shop for piecemeal diagnostics of the parts. The PSU could be appearing to work but is missing a rail, there could be damage to the motherboard, and/or your processor might have been damaged.
How do you know that your motherboard is not working and that it isn't your RAM?
It could be just about anything to be honest. What testing have you done other than pulling out the RAM? If you remove the RAM and the motherboard beeps that is a good sign. It is telling you that the motherboard is able to detect that no RAM is installed. It may not me be the motherboard. It could be the RAM, it could be the graphics card. It is hard to tell.
Yeah my pc was running...It opens fine when i press the power button and just keeps black screen w/o any beep(1 only to confirm that BIOS is ok)I dont know much but when ur PSU get fried it should open the PC at all right?
When the RAM isnt plugged the beep beep beep etc...isnt heard...No beep beep at all...From a few things i know when the RAM isnt plugged it should be a lot of beep beep should heard...Now w/o the RAM plugged it just keeps the pc running w/o booting or anything at all..No beep beep beep...No boot...No nothing
The problem is that when i press the power button it just keeps me at black screen w/o any BIOS setting...Boot setting and the other staff it gets...Any other idea?
Nothing at all it is coming up from the motherboard...The power comes fine through the PSU and after it just keep runining w/o doing anything at all...Just keeps the screen at black and the cooler of CPU runs fine enough...That's all it is doing..
I had a Intel 2 Duo plugeed and i have a 2nd one Intel Core 2 Quad Q9550...I dont care about the CPU cause i have an extra one...The problem is that i dont have an extra Graphic Card and this PC was 90% for gaming...(LOL,GTA IV,DOTA 2 etc...)I quess i have to go and make a diagnosis at a shop to see what exacly is the problem
