Friends,
i have this card i purchased 4 moths ago... its a 4850 with gddr5 memory..
its safe to say that it has the RV770 chip on it...
now..
i OCed it to
core@760mhz.
memory@4050mhz
this pretty much shud equal/exceed any stock 4870...
THE CATCH.....
i have this craptastic tin can<gonna go i7 in december>-
3.87 ghz pent d.. PRESLER<ya... the old one>
2 gb kingston
600 w cooler master psu...
Tempz..
Idle- 55- 60 c.. <31 c ambient>
load-75c the MAX i eva saw it.....<furmark>
Now for the depressing part-
RESOLUTION- 1024x768
Nearly everthing maxed out..
MAX AVG MIN
fallout- 60 <vsync> 30-35 18
Gears of war- 65 40 24
Dead space- 71 36 22
Nfs Shift- 60 <vsync> 25 18
Bioshock 82 45 28
I m on catalyst 9.5 <9.9 gives even more crap> with ATI Tray tools
HELP..
WTF? is the F'ing Problem???????
the cpu bottleneck cannot be SO great..... <can it?>
i Oced the cpu frm 3.00 to 3.87 ghz....
and still these results..<although fallout's performance did increase...>
What ATi tray tools tells about my card-
Display adapter ATI Radeon Graphics Processor (0x9442)
Core Name RV770
SubVendor Unknown 0000
SubDevice 0000
BUS 1
Device 0
Function 0
Base Address 0 E000000C
Base Address 1 00000000
Base Address 2 FEAE0004
Base Address 3 00000000
Bus Type Supported PCI Express 2.x
PCI-E Link Width 16
Max PCI-E Link Width 16
SMARTGART Installed No
Driver Version 09.5
Release Version 8.612-090428a-080257C-ATI
QuadBuffer Stereo Support No
Catalyst Registry Path
System\CurrentControlSet\Control\Video\{B46E5A5B-823B-4398-92D3-5C8FBC333EEF}\0000
______________________________
Clock Information
BIOS VPU 700.00
Current VPU 765.00
BIOS MEM 900.00
Current MEM 1012.50
Overdrive
Adapter 0
Supported Yes
Type PowerPlay
Level 0 : GPU/MEM/VDDC 765.00/1012.50/1.263
Level 1 : GPU/MEM/VDDC 765.00/1012.50/1.263
Level 2 : GPU/MEM/VDDC 765.00/1012.50/1.263
Radeon PCI configuration space
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 02 10 42 94 07 00 10 00 00 00 00 03 08 00 80 00
10 0C 00 00 E0 00 00 00 00 04 00 AE FE 00 00 00 00
20 01 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 AC FE 50 00 00 00 00 00 00 00 10 01 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 01 58 03 06 00 00 00 00 10 A0 12 00 A0 8F 2C 01
60 10 09 00 00 01 0D 00 00 40 00 01 11 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Hardware Information ASIC (Software) Method
Family 81
Emulated Revision 2
Gfx Engine ID 6
VRam Bit Width 256
Installed memory 512
OverDrive 5
Core clocks Min 385.00 - Max 750.00
Memory clocks Min 510.00 - Max 950.00
VDDC Min 1.083v - Max 1.263v
FAN
1 12324080
2 50D31A05
3 4B46413C
4 625A5550
5 605A544D
6 80746D67
Video BIOS Information
Version 011.013.000.002
Part Number 113-AA48509070.28
Date 2009/02/10 01:04
Vram Type GDDR5
Controller Configurations
Controller 0
Active Connections:
-Second Monitor (CRT2) (0) 1024x768x85
Controller 1
Active Connections:
No Active Connections
Displays supported by adapter
0 (1) Monitor (CRT1)
1 (2) Second Monitor (CRT2)
2 (4) Digital Flat Panel
3 (8) Digital Flat Panel
4 (16) Second Digital Flat Panel
EnumDisplays
Display Type 0, Extended Type 1 , Max Resolution 1600x1200
Display Type 0, Extended Type 2 , Max Resolution 1920x1080
Display Type 3, Extended Type 1 , Max Resolution 0x0
Display Type 3, Extended Type 3 , Max Resolution 0x0
Display Type 3, Extended Type 2 , Max Resolution 0x0
Loaded Displays
Display 1 index 1
Display 2 index 2
TV Index 61440
Multi VPU Caps
No additional information
Multi VPU State
ulActiveAdapters 0
ulAvailableAdapters 0
ulCurrentAdapter 0
ulDongleCapabilities 0
ulDongleConnection 0
ulDongleDisplayIndex 0
ulPrimaryIndex 0
ulMVPUMaxFBSize 0
ulMVPUMaxPipes 0
ulMVPUMaxVisFBSize 0
ulMVPUState 0
State Bits
now..
i OCed it to
core@760mhz.
memory@4050mhz
THE CATCH.....
2 gb kingston
Tempz..
MAX AVG MIN
Bioshock 82 45 28
HELP..
Core Name RV770
SubDevice 0000
BUS 1
Device 0
Function 0
PCI-E Link Width 16
Driver Version 09.5
Clock Information
BIOS VPU 700.00
Current VPU 765.00
BIOS MEM 900.00
Current MEM 1012.50
Overdrive
Adapter 0
Supported Yes
Type PowerPlay
Family 81
Emulated Revision 2
Gfx Engine ID 6
VRam Bit Width 256
OverDrive 5
FAN
1 12324080
2 50D31A05
3 4B46413C
4 625A5550
5 605A544D
6 80746D67
Vram Type GDDR5
Controller 0
Active Connections:
Controller 1
Active Connections:
EnumDisplays
Loaded Displays
Display 1 index 1
Display 2 index 2
TV Index 61440
Multi VPU Caps
Multi VPU State
ulActiveAdapters 0
ulCurrentAdapter 0
ulPrimaryIndex 0
ulMVPUMaxFBSize 0
ulMVPUMaxPipes 0
ulMVPUState 0
State Bits
