Specs:
Ryzen 5 5600x
FX 5600XT
Corsair vengeance 4x 8gb
ASUS tuff b450m plus 2
500w evea 80+
500gb m.2 Wd blue
right so I upgraded from a 2600 to a 5600x but my old BIOS needed flashing which then killed my old mobo.
New motherboard came it all back together and now my gpu won’t run? No fans or display and I’ve tried my old gpu which doesn’t work either ?
all lights and fans running.
Yes I’ve plugged the 8 pin power in and I’ve seated all way I can including the click of the pci clip
any help I use my pc for work and I’m missing out for 7 days so far
Ryzen 5 5600x
FX 5600XT
500w evea 80+
500gb m.2 Wd blue
