HELP! I Changed my Benq GL2460 to Low Blue Light and I don't know how to change back!
Get the on screen menu to where you can see SYSTEM (left side of screen along with Display, Audio etc)
Select SYSTEM, then scroll down till you see RESET ALL at the very bottom and select it, then hit "Yes".
Factory defaults should be restored, Viola'
Now select this as the answer.. LOL.
Just take out your manual and look it up.
Don't have the manual then download it and look it up.
How else do you think anyone on here would find out how to change the settings, im sure there has to be a couple people with that exact model on here but now you are playing a very low probability game.
LOL, I figured already but thanks! Any way i can switch without having to reset every time?
