My problem is this.
I have an HP Compaq Presario CQ42 notebook that I bought in 2012 running Windows 7. I have Avast Antivirus and have run Malwarebytes.
Lately, (the past 6 months) I've been having several issues.
1) The first one to appear was the refusal to wake up from hibernation/sleep. The computer will spool up the fan and the light will come on, but it will never wake up. I have to cut power and take out the battery to get it to restart. This is maddening because it only happens sometimes.
2) I have learned the full compendium of BSOD's. I have had IRql_not_less_or_equal crashes on both startup and in normal operation. I have had a Bad Pool Header Error. I have had a Systems Service Exception. All of this in just the last week. I've had it happen in a System restore.
3) I have had the "Display driver stopped responding and has recovered" error. Sometimes it happens all the time, sometimes it goes for days without.
I can find answers to all of these problems in isolation, but I don't know if they are connected to a bigger issue. I want to know what would be the procedure for isolating and fixing these problems.
My question here is how to go about doing that. What should I try to tackle first and how?
Thanks so much!
UPDATE: I was also able to fix my graphic driver issues by downloading the latest off of HP. My computer is a compaq presario CQ42 301-AX (I wasn't able to get to that last part without taking out the battery.) I tried updating the BIOS but actually have the latest version already.) I'm fully backed up (though not with a proper windows backup or disk image both of those crash when tried, instead I've literally copied everything onto an external drive.)
So I made myself a memtest86 disk, the first time I ran it, the computer suicided after about 20 minutes. I broke down my laptop, cleaned out the fans and then ran memtest86 again. This time everything went fine.
I also gave myself the red laptop screen problem (though this one is just annoying and my computer had it once before, to fix it, I have to disconnect and reconnect the LCD) .
Windows startup repair doesn't work. It hasn't worked repeatedly, but the latest one I actually had the presence of mind to record the details.
"Startup Repair cannot repair this computer"
Problem event name: Startup repair offline
Problem Signature 01: 6.1.7600.16385
Problem Signature 02: 6.1.7600.16385
Problem Signature 03: unknown
Problem Signature 04: 102
Problem Signature 05: Autofailover
Problem Signature 06: 1
Problem Signature 07: No Root Cause
OS: 6.1.7600.2.0.0.256.1
LocaleID: 1033
So I had also made a windows repair disk. (I don't have the original installation disk, windows came pre intstalled) and I tried to boot from it at startup.
I got the "Couldn't find Bootmgr" error. I got back into windows, checked the CD and Bootmanager is on there. I know it's not a problem with the CD drive because my memtest86 CD was able to run and boot just fine.
I'm really mystified as to why the windows repair disk isn't booting.
Thanks so much!
LocaleID: 1033
