Help! (i need help finding the right PSU)
ryanb213
216
Ok so everybody knows the story " i need help finding a correct PSU"... Well i myself have the same dillema.
Ok so here are the specs (i do not need modular, just simple)
Intel Core 2 Quad Q600 G0
EVGA 750i FTW motherboard
4GB (2 x 2GB) 800 MHz memory
EVGA 9800GTX+
3 SATA DRIVES
3 120mm case fans
ive gotten from 400w to 800w and im thinking all i need is 500-600w
please help me
helios2052
194
The Corsair 650TX would be perfect for you and is one of the most stable and well recognized power supplies currently on the market.
If you want to future proof, grab the 750TX.
ryanb213
216
see i thought 650w would be too much, i was looking @ 550w psu's oh btw
i need something thats extremely energy efficent, i mean very-very efficent i dont want anything to run up my electric bill it is prob more important than cost because it will save money in the long run
Noya
812
650tx $72 after rebate:
http://www.buy.com/prod/corsair-650w-tx-series-80-plus-certified-power-supply-corsair-tx-cmpsu/q/loc/101/206178324.html
The 550vx is the same $72 right now, making the 650tx a better buy:
http://www.buy.com/prod/corsair-550w-vx-series-12v-atx-80-plus-certified-power-supply-corsair/q/loc/101/205852646.html
I think every Corsair is a 80%+ efficient rated, and most PSU's are at their peak efficiency while under about a 50% load:
http://www.corsairmemory.com/_images/charts/tx650w_efficiency.jpg
So I think the 650tx is your best value choice right now.
Ares_
83
The corsair 450 should work for your system, but i would go for the 650 if you have the money and want to use the PSU with your next build.
ryanb213
216
no i do not want to use the psu in my next build again i see people buying 850w psu's for their pc with exact same specs as mine!!! you dont need that much but would a 450 really do it??
Noya
812
With shipping you're looking at $130...I don't think it's a good deal.
BAM:
http://www.buy.com/prod/cooler-master-690-without-power-supply/q/loc/101/206177908.html
Same case for $77 shipped. Add the $72 Corsair TX650 and you're paying $19 more and getting a much better PSU.
Or a decent Antec 300 for $51 shipped:
http://www.buy.com/prod/antec-three-hundred-atx-computer-case/q/loc/101/207906549.html
Noya
812
I'm using the Corsair 450vx in my aging rig (90nm AMD Opteron dual core @ 2.25ghz, 4 sticks of RAM, 2 DVD burners, 3 7200rpm hard drives, 4 fans and an eVGA overclocked 9600GT). It works fine. But for less than $20 more I would get the 650tx.
Ares_
83
A 450 would do it.
My friend is using one on his E6550, 4850, 2 WD640s and it runs fine. I belive the 450 is better than my OCZ 600, and that runs a 4870, my OCed Quad, X-fi, 2 seagates just dandy. I saw it for $40 in the newegg newsletter the other day, it is not as high quality as the corsairs but it should run your rig.
ryanb213
216
link?
Noya
812
$61 shipped for that? Thumbs down :non:
I think you should just go with the separate case and 650 PSU on buy.com. It has 52amps on the +12v, it has the 2 x 6-pin PCIe connectors for your GTX+, and it's at peak efficiency at about 300-350 watts- about what you'll be using when gaming on an OC'ed Q6600. It's about $20 more than the one on newegg with the lower quality PSU. $20 = no headaches...well worth it IMO.
Similar threads
