Help I need new parts but dont know what to get.
Jakerr11
Commendable
Jun 15, 2016
6
Any HELP would be much appreciated! Im looking to kinda build a new pc I already have some parts that I think i can reuse. Such as my GPU, RAM, CPU. My current computer that I got about 4 years ago and its been fine till now. It is a HP Pavilion HPE h9 series. The reason that I wanna do this is because my stock case that I have everything in now is too cramped for my GPU and my stock fan for my CPU really isn't pushing heat out. I really want to be able to use the 2 extra fans that have in my Corsair tower. My current hard drive won't fit in the hard drive cage in the Corsair tower unless forced in.
What I have:
Intel i7-3770
Amd Radeon R9 290 4g Gddr5
Corsair spec 01 mid tower
2 120mm Corsair fans
12g RAM
Stock HP 600 watt Power supply unit (isnt really useful in Corsair case)
What I think might need to finish the build I want.
ASRock Micro ATX DDR3 1066 Motherboards 970M PRO3
Corsair CX600 CP-9020048-US 600W Power Supply
WD Blue 2TB Desktop Hard Disk Drive - 5400 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch - WD20EZRZ
Any other information very helpful please! Thank you.
That motherboards is for AMD processors.
For your processor, you will need a socket 1155 motherboard.
Everything else looks good.
Just look on amazon for ATX cases and you can find some nice ones. If you are air cooling then I would recommend the NZXT S340
