HELP ~ I Notice Pixels???!! ~ HELP
runordie
46
Hey everyone, today I received my new laptop and have an question boggling my mind.
When comparing the newer version laptop with an older laptop (both are Sony Vaio S series) I can notice the pixels (the little squares) alot easier on the better and newer Vaio S series laptop. Both are at 1600x900 resolution so I am very stunned as to why that is. I also only notice these pixels (tiny squares) on lower resolution displays like the 1366x728 displays.
I also notice that the whites (eg. from the Google homepage) is better in the older Vaio than the new Vaio S series.
The only positive about the new Vaio S series is the colors are more vibrant.
runordie
46
Hey thanks for the quick response.
Sorry for the confusion.
Both laptops are 13.3" at 1600x900 and at the same brightness levels. (Not sure if everyone's knows what I am talking about by saying "Pixels are more noticeable"...
I have a good idea;
Check your check on the pixel dot pitch specs for each of the models? Any difference there?
It might be listed as something like Pixel Resolution Pitch 0.1935 mm
Beyond that, the only thing I can think or ATM is the relative brightness of one screen vs the other makes them more apparent.
runordie
46
OMG! Thanks so much!
I just went to an Pixel Resolution Pitch Calculator and with the new Vaio S at 1600x900, it was detected as 1506x847 and the old Vaio S version is indeed 1600x900.....
What is going on there? That must be the key!
PS: I also want to add that texts are easier and less "blurry" to read on the older Vaio S Series....
I am now totally confused...
definitely something going on there. It's a hardware 1600x900 pixel LCD screen.
I wonder if that could be some driver issue?
Are there any return to 'default setting options' that you can see?
I'm thinking the laptop and screen is trying to figure out how to switch on 1506x847 'logical pixels' on a screen that has 1600x900 actual pixels.
Have there been any software programs loaded (not installed at the factory) that might mess around with display settings?
Did you use http://www.screenresolution.org/ to test your resolution?
What does Control Panel Display settings tell you?
Google isn't turning up anything useful on 1506x847 resolution
-> except that you're not alone with that being detected on sites like http://www.screenresolution.org/
I think you'd better run this by Sony Tech Support.
The only other suggest I can think of is to go ahead and use Display Manager and change to some of the other optional settings (1366x768 or 1280x720 for example) and see if you notice any changes in the texture of the pixels.
If you have a magnifying glass you should be able to visualize the individual physical pixels.
userxvi-JOE
19
Have you tried plugging in external TV/Monitors to try and narrow this down?
Don't forget, in the states you have 7-30 days to get your cash back depending in which state you live in (after receiving the package), anything more and the law is not 100% on your side any more, and good luck.
Just saying, Plan on not getting stuck with a "refurbished" or defective unit if it comes to that.
