Hello, I need some help with my PC as I think I may have fried it
I was trying to get the PC ready for windows 11 and turned on TPM, rebooted and ran the tool to see if Windows 11 would work and it said that I needed to turn on secure boot, went back into the BIOS and activated secure boot. The next bit I am not 100% sure on what was said however it was something like needed profile key or something similar which I activated, said one wasn’t assigned and did I want to use the default. I said yes and rebooted.
The PC now has black screen and beeps 5 times but if I remove the GPU it will boot to BIOS but wont boot to windows, BIOS looks different and also says it cant find any boot drives.
Its Gigabyte z370p d3 MB which says the 5 beeps are a CPU issue but why does it not show the boot drives? I have also tried to reset the BIOS with no luck
Any help would be greatly received as I can't afford to replace any parts and need the PC for working from home.
