http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=2%2050001157%2040000343&bop=And&ActiveSearchResult=True&CompareItemList=N82E16819115215%2CN82E16819115214%2CN82E16819115202
Not sure which to go with yet.
i5 750:
The i5 750 ($190.00) is a bit cheaper than the i7 920 and i7 860 (both $230.00). The i5 has same processing speed as the i7 920 (2.66ghz x4) but doesn't support hyper-threading. It also uses the LGA 1156 socket, which has cheaper motherboards. Can easily save $100.00 between the processor and motherboard.
i7 920:
I've known of this one for a while, and have heard nothing but the very best. Though I hear the i5 750's performance is nearly as good if not the same, and it costs a bit less. A key benefit over the i5 750 is that it supports hyper-threading. It uses the LGA 1366 socket which usually has pricier motherboards.
i7 860:
I just heard of this a short while ago. At the same price as the i7 920, it seem like it may be a better option. It has higher processing speed with 2.8ghz x4 vs the i7 920 and i5 750's 2.66ghz. Like the i5 750 it uses the LGA 1156 socket which should mean cheaper motherboards.
i5 750:
i7 920:
i7 860:
