Help ID an adapter or to make these compatible please?
rambo244
66
5
18,535
Hey guys I was wondering if anybody could ID an adapter that would allow these 2 things to work together if possible?
View: https://imgur.com/a/4P4W50r
I need to plug the white wire in to the red hole that is labeled #1 on my DVR box.
It's to output video from the DVR to another monitor I have in a separate location.
I just replaced my old DVR box with this new one pictured - and the white wire that outputs video to my other monitor doesn't fit in to the red hole of this new DVR pictured.
Any help would be greatly appreciated, thank you very much!
Yes I see what you are saying about that - buy the manual shows that #1 hole to be a Video OUT - so hoping thats the case!!!
thanks - just ordered an adapter!
You may want to list exactly what you have, brands and models instead of just showing pictures of the cable and connector.
