Question Help identify model of graphics card.
@METAL - Given it's an AGP card, that might be more difficult to do.
@dylanveasey - The red PCB first told me it was an ATI Radeon card, but the info I've found (likely the same you've found) says the MX 440, but every image I come across shows the VGA as the lowest port. Not the S-Video/Composite port.
If you have a system with an AGP port, then I'd suggest as Metal does.
-Wolf sends
Yes yes....`That Creative Labs Model did came up before while I was doing some search, lol.
Sometimes I wish I still had my old Athlon X2-4800+ and 939Dual-SATAII motherboard with both AGP and PCIE.
Indeed. Even I miss those good 'ol PC days. The AGP, Voodoo, 3DFX, Riva TNT era more like...
