[SOLVED] Help identify motherboard
Apr 8, 2020
5
Hello,
I am unable to find the model of my motherboard. I want to check what is the maximum RAM supported.
Here is cpuz report
CPU-Z TXT Report
Binaries
CPU-Z version 1.94.0.x64
Processors
Number of sockets 1
Number of threads 4
APICs
Socket 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Thread 1 1
-- Core 1 (ID 2)
-- Thread 2 4
-- Thread 3 5
Timers
ACPI timer 3.580 MHz
Perf timer 10.000 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 2 (max 2)
Number of threads 4 (max 4)
Manufacturer GenuineIntel
Name Intel Core i5 540M
Codename Arrandale
Specification Intel(R) Core(TM) i5 CPU M 540 @ 2.53GHz
Package (platform ID) Socket 989 rPGA (0x4)
CPUID 6.5.5
Extended CPUID 6.25
Core Stepping K0
Technology 32 nm
TDP Limit 25.0 Watts
Core Speed 2525.9 MHz
Multiplier x Bus Speed 19.0 x 132.9 MHz
Base frequency (cores) 132.9 MHz
Base frequency (ext.) 132.9 MHz
Rated Bus speed 2393.0 MHz
Stock frequency 2533 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES
Microcode Revision 0x7
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 4-way set associative, 64-byte line size
L2 cache 2 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 3 MBytes, 12-way set associative, 64-byte line size
Max CPUID level 0000000Bh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 3 MB, 16 thread(s)
FID/VID Control yes
Turbo Mode supported, disabled
Max turbo frequency 3066 MHz
Max non-turbo ratio 19x
Max turbo ratio 23x
Max efficiency ratio 9x
TDC Limit 25 Amps
Max bus number 255
Attached device PCI device at bus 255, device 2, function 1
Temperature 0 100 degC (212 degF) (Core #0)
Temperature 1 101 degC (213 degF) (Core #1)
Power 00 25.00 W (Package)
Clock Speed 0 2525.94 MHz (Core #0)
Clock Speed 1 2525.94 MHz (Core #1)
Core 0 max ratio 23.0 (effective 19.0)
Core 1 max ratio 23.0 (effective 19.0)
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
CPUID
0x00000000 0x0000000B 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x00020655 0x00100800 0x029AE3FF 0xBFEBFBFF
0x00000002 0x55035A01 0x00F0B2DD 0x00000000 0x09CA212C
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x00C0003F 0x0000007F 0x00000000
0x00000004 0x1C004143 0x01C0003F 0x000001FF 0x00000000
0x00000004 0x1C03C163 0x02C0003F 0x00000FFF 0x00000002
0x00000005 0x00000040 0x00000040 0x00000003 0x00001120
0x00000006 0x00000005 0x00000002 0x00000001 0x00000000
0x00000007 0x00000000 0x00000000 0x00000000 0x9C000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300403 0x00000004 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000000
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000001 0x28100800
0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865
0x80000003 0x35692029 0x55504320 0x20202020 0x4D202020
0x80000004 0x30343520 0x20402020 0x33352E32 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00000007
MSR 0x00000048 0x00000000 0x00000000
MSR 0x000001A0 0x00000040 0x00850089
MSR 0x000000CE 0x00000900 0x20011300
MSR 0x00000017 0x00100000 0x00000000
MSR 0x00000035 0x00000000 0x00020004
MSR 0x000000C1 0x00000000 0x00000000
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x0000FFFF 0xFFE7B15B
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x00000000 0x00001517
MSR 0x0000019A 0x00000000 0x00000000
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001AC 0x00000000 0x00C800C8
MSR 0x000001FC 0x00000000 0x00000002
MSR 0x00000300 0x00000000 0xE0000001
MSR 0x0000019C 0x00000000 0x880402A2
MSR 0x000001A2 0x00000000 0x00690A00
MSR 0x00000198 0x00000000 0x0000000B
MSR 0x00000199 0x00000000 0x00000013
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 0, Thread ID 1
CPUID
0x00000001 0x00020655 0x01100800 0x029AE3FF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000001
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000001
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x000000C4 0x0000FFFF 0xFFDBA47D
MSR 0x0000019C 0x00000000 0x880502A2
CPU Thread 2
APIC ID 4
Topology Processor ID 0, Core ID 2, Thread ID 0
CPUID
0x00000001 0x00020655 0x04100800 0x029AE3FF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000004
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000004
MSR 0x000000C4 0x0000FFFF 0xFFDF4CC0
MSR 0x0000019C 0x00000000 0x880102A2
MSR 0x00000198 0x00000000 0x00000009
CPU Thread 3
APIC ID 5
Topology Processor ID 0, Core ID 2, Thread ID 1
CPUID
0x00000001 0x00020655 0x05100800 0x029AE3FF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000005
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000005
MSR 0x000000C4 0x0000FFFF 0xFFE0B2FF
MSR 0x0000019C 0x00000000 0x880003E3
BIOS
UEFI No
BIOS Vendor American Megatrends Inc.
BIOS MSG 64-0100-000001-00101111-070715-LfdHvdImc
BIOS Date 07/07/15
Mainboard Vendor 000001
Chipset
Northbridge Intel Havendale/Clarkdale Host Bridge rev. 18
Southbridge Intel QM57 rev. 06
Memory Type DDR3
Memory Size 8 GBytes
Channels Dual, (Symmetric)
Memory Frequency 531.8 MHz (4:16)
CAS# latency (CL) 7.0
RAS# to CAS# delay (tRCD) 7
RAS# Precharge (tRP) 7
Cycle Time (tRAS) 20
Row Refresh Cycle Time (tRFC) 160
Command Rate (CR) 1T
Host Bridge 0x0044
Host Bridge 0x2C62
Host Bridge 0x2D01
Host Bridge 0x2D10
Host Bridge 0x2D11
Host Bridge 0x2D12
Host Bridge 0x2D13
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Module Manufacturer(ID) (00000000000000000000000000)
Size 4096 MBytes
Max bandwidth PC3-10700 (667 MHz)
Part number
Manufacturing date Week 35/Year 14
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP no
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 5.0-5-5-14-19 @ 380 MHz
JEDEC #2 6.0-6-6-17-23 @ 457 MHz
JEDEC #3 7.0-7-7-20-27 @ 533 MHz
JEDEC #4 8.0-8-8-22-30 @ 609 MHz
JEDEC #5 9.0-9-9-24-33 @ 666 MHz
JEDEC #6 10.0-9-9-24-33 @ 666 MHz
DIMM # 2
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Size 4096 MBytes
Part number
Number of banks 8
EPP no
XMP no
AMP no
DIMM # 1
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 92 10 0B 02 03 19 00 09 03 52 01 08 0C 00 7E 00
10 69 78 69 30 69 11 20 89 60 09 3C 3C 00 F0 83 05
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 14 35 00 00 00 00 06 7A
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 FF
DIMM # 2
SPD registers
Monitoring
Mainboard Model To be filled by O.E.M. (0x000006C0 - 0xE87917D0)
LPCIO
LPCIO Vendor Nuvoton
LPCIO Model NCT6779
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xC5
LPCIO Revision ID 0x62
Config Mode I/O address 0x2E
Config Mode LDN 0xB
Config Mode registers
00 FF FF 00 FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF F0 78 00 00 FF FF
20 C5 62 FF 00 64 00 00 00 00 FF 40 60 01 FF 00 01
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 0A 10 00 00 FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0A10
Hardware Monitors
Hardware monitor Nuvoton NCT6779
Voltage 0 0.86 Volts [0x6B] (CPU VCORE)
Voltage 2 3.17 Volts [0xC6] (AVCC)
Voltage 3 3.15 Volts [0xC5] (3VCC)
Voltage 6 1.06 Volts [0x84] (VIN6)
Voltage 7 0.11 Volts [0xE] (VIN7)
Voltage 8 0.86 Volts [0x6B] (VIN8)
Voltage 9 1.56 Volts [0xC3] (VIN9)
Voltage 10 0.00 Volts [0x0] (VIN10)
Voltage 11 0.00 Volts [0x0] (VIN11)
Voltage 12 1.06 Volts [0x84] (VIN12)
Voltage 13 0.94 Volts [0x76] (VIN13)
Voltage 14 0.12 Volts [0xF] (VIN14)
Voltage 15 1.58 Volts [0xC5] (VIN15)
Temperature 3 40 degC (104 degF) [0x28] (TMPIN3)
Temperature 5 66 degC (150 degF) [0xC2] (TMPIN5)
Temperature 6 121 degC (249 degF) [0x79] (TMPIN6)
Temperature 8 111 degC (231 degF) [0x6F] (TMPIN8)
Fan 0 1925 RPM [0x785] (SYSFANIN)
Hardware registers
bank 0
00 03 7F 03 7F 01 FF FF FF FF FF FF FF FF FF FF FF
10 03 FF 03 FF 03 FF FF FF 40 00 0E 0F 76 C3 14 00
20 6C 00 C3 C5 00 00 84 79 FF FF FF DA 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF
40 03 1C 52 FF DF 00 1F FF 2D FF FF 10 08 55 00 A3
50 01 FF FF FF FF FF FF FF C1 FF FF FF FF 05 00 FF
60 AA FF FF FF FF 01 00 FF FF FF FF FF FF FF FF FF
70 00 0A 00 79 00 C2 00 0D 00 0D 00 0D 00 FF FF FF
80 FF 7F 1F BF FF 05 05 05 00 00 00 00 00 00 00 00
90 0A 00 00 00 00 FD FD FD 0A 95 EF 80 FF 40 46 C4
A0 0E FF 00 00 FF 00 00 FF 00 00 80 66 06 06 00 00
B0 00 00 00 00 00 00 2F 00 04 00 00 34 28 80 04 FF
C0 FF FF FF FF FF FF FF FF FF 05 06 05 FF FF FF FF
D0 05 05 05 05 00 00 00 00 00 00 00 00 FD FD FD FD
E0 55 80 00 00 00 FF FF FF FF FF FF FF FF FF FF FF
F0 00 00 00 00 00 00 00 00 00 00 00 00 C7 FF FF FF
bank 4
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF
20 FF FF FF 96 64 96 64 E1 96 04 FF FF FF FF FF FF
30 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF 03 28 FF FF FF FF FF FF 00 00 00 00 04 FF
50 03 73 FF FF 00 FE F5 FF FF 1C 02 13 09 FF FF FF
60 FF 01 00 00 00 00 00 00 FF FF FF FF FF FF FF FF
70 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
80 6C 00 C3 C3 00 00 84 D2 CC 00 0E 0F 76 C3 14 00
90 79 C2 0D 70 6F 71 00 2F 80 79 C2 0D 0D 0D 00 FF
A0 79 79 79 79 79 00 00 00 00 00 00 00 00 00 00 00
B0 15 1D FF 1F FF 1F FF 1F FF 1F FF FF FF FF FF FF
C0 07 85 00 00 00 00 00 00 00 00 FF FF FF FF FF FF
D0 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF
E0 7F 7F FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor Hardware monitor ID=0xFFFFFFFF
Hardware monitor D3D
PCI Devices
Register space PCI Express, base address = 0x0E0000000
Description Host Bridge
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x0044
Revision ID 0x18
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x8086
Subsystem ID 0x0044
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class Vendor Dependant
Caps offset 0xE0
PCI registers
00 86 80 44 00 06 00 90 20 18 00 00 06 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 86 80 44 00
30 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00
40 01 90 D1 FE 00 00 00 00 01 40 D1 FE 00 00 00 00
50 00 00 50 03 09 01 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 01 80 D1 FE 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 7F 00 8E 00 00 00 00 00
A0 80 00 C0 23 00 00 00 BE 00 00 E0 BD 00 00 80 BB
B0 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00
D0 00 00 00 00 03 03 00 00 00 00 00 00 00 00 00 82
E0 09 00 0C 01 26 61 21 00 88 00 40 00 00 00 00 00
F0 00 00 00 00 0D 00 00 00 AB 0F 18 00 00 00 00 00
Description VGA Controller
Location bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x0046
Revision ID 0x18
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFB800000
Address 2 (memory) 0xD0000000
Address 4 (port) 0x0000DC00
Subvendor ID 0x8086
Subsystem ID 0x0046
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps class Message Signalled Interrupts
Caps offset 0x90
PCI capability
Caps class Power Management
Caps offset 0xD0
Caps version 1.1
PCI capability
Caps class 0x13
Caps offset 0xA4
PCI registers
00 86 80 46 00 07 04 90 00 18 00 00 03 00 00 00 00
10 04 00 80 FB 00 00 00 00 0C 00 00 D0 00 00 00 00
20 01 DC 00 00 00 00 00 00 00 00 00 00 86 80 46 00
30 00 00 00 00 90 00 00 00 00 00 00 00 00 01 00 00
40 09 00 0C 01 26 61 21 00 88 00 40 00 0F 17 17 17
50 00 00 50 03 09 01 00 00 00 00 00 00 00 00 00 BE
60 00 00 02 02 00 00 00 00 00 00 00 00 00 00 00 00
90 05 D0 01 00 0C F0 E0 FE A2 49 00 00 00 00 00 00
A0 11 11 11 00 13 00 06 03 00 00 14 60 25 04 3A 30
B0 00 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00
D0 01 A4 22 00 00 00 00 00 00 00 00 00 00 01 02 00
E0 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 AB 0F 18 00 00 00 00 00
Description Data Aquisition and Signal Processing Device
Location bus 0 (0x00), device 4 (0x04), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x0050
Revision ID 0x18
PI 0x00
SubClass 0x80
BaseClass 0x11
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFBFF4000
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x0A
Int. Pin 0x01
PCI capability
Caps offset 0x90
PCI capability
Caps offset 0xD0
Caps version 1.2
PCI registers
00 86 80 50 00 02 00 90 00 18 00 80 11 00 00 00 00
10 04 40 FF FB 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 90 00 00 00 00 00 00 00 0A 01 00 00
40 00 00 00 00 48 00 00 00 09 00 0A 01 00 00 00 00
50 00 00 00 00 4B 00 00 00 00 00 00 00 00 00 00 00
90 05 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 01 00 03 00 08 00 00 00 00 00 00 00 00 00 00 00
Description USB Controller (UHCI)
Location bus 0 (0x00), device 26 (0x1A), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x3B3B
Revision ID 0x06
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 4 (port) 0x0000D880
Subvendor ID 0x8086
Subsystem ID 0x3B3B
Int. Line 0x15
Int. Pin 0x02
PCI capability
Caps class 0x13
Caps offset 0x50
PCI registers
00 86 80 3B 3B 05 00 90 02 06 00 03 0C 00 00 80 00
20 81 D8 00 00 00 00 00 00 00 00 00 00 86 80 3B 3B
30 00 00 00 00 50 00 00 00 00 00 00 00 15 02 00 00
50 13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00
60 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 20 00 00 00 00 00 00 04 00 01 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 87 0F 07 08 00 00 00 00
Location bus 0 (0x00), device 26 (0x1A), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x3B3E
Revision ID 0x06
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000D800
Subvendor ID 0x8086
Subsystem ID 0x3B3E
Int. Line 0x12
Int. Pin 0x03
PCI capability
Caps class 0x13
Caps offset 0x50
PCI registers
00 86 80 3E 3B 05 00 90 02 06 00 03 0C 00 00 00 00
20 01 D8 00 00 00 00 00 00 00 00 00 00 86 80 3E 3B
30 00 00 00 00 50 00 00 00 00 00 00 00 12 03 00 00
Location bus 0 (0x00), device 26 (0x1A), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x3B3F
Revision ID 0x06
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000D480
Subvendor ID 0x8086
Subsystem ID 0x3B3F
Int. Line 0x13
Int. Pin 0x04
PCI capability
Caps class 0x13
Caps offset 0x50
PCI registers
00 86 80 3F 3B 05 00 90 02 06 00 03 0C 00 00 00 00
20 81 D4 00 00 00 00 00 00 00 00 00 00 86 80 3F 3B
30 00 00 00 00 50 00 00 00 00 00 00 00 13 04 00 00
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 26 (0x1A), function 7 (0x07)
Common header
Vendor ID 0x8086
Model ID 0x3B3C
Revision ID 0x06
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFBFF2000
Subvendor ID 0x8086
Subsystem ID 0x3B3C
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps class Debug Port
Caps offset 0x58
PCI capability
Caps class 0x13
Caps offset 0x98
PCI registers
00 86 80 3C 3B 06 00 90 02 06 20 03 0C 00 00 00 00
10 00 20 FF FB 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 86 80 3C 3B
30 00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
50 01 58 C2 C9 00 00 00 00 0A 98 A0 20 00 00 00 00
60 20 20 FF 07 00 00 00 00 01 00 00 00 00 20 00 C0
70 01 00 CE 3F 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 80 00 11 91 0C 13 A0 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 13 00 06 03 00 00 00 00
D0 00 00 00 00 00 AA FF 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 20 59 0B 8E
F0 00 00 00 00 88 85 8C 00 87 0F 07 08 68 17 5B 30
Description Multimedia device
Location bus 0 (0x00), device 27 (0x1B), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x3B56
Revision ID 0x06
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x08
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFBFEC000
Subvendor ID 0x8086
Subsystem ID 0x3B56
Int. Line 0x16
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps offset 0x60
PCI capability
Caps class PCI Express
Caps offset 0x70
Device type Root Complex Integrated Endpoint Device
Port 0
Version 1.0
Link width 0x (max 0x)
Extended capabilities
Caps class Virtual Channel
Caps offset 0x100
Caps class Root Complex Link Declaration
Caps offset 0x130
Link Entries # 1
Port Number 15
PCI registers
00 86 80 56 3B 06 00 10 00 06 00 03 04 08 00 00 00
10 04 C0 FE FB 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 86 80 56 3B
30 00 00 00 00 50 00 00 00 00 00 00 00 16 01 00 00
40 01 00 00 47 01 00 00 00 00 00 00 00 00 00 00 00
50 01 60 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
60 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
70 10 00 91 00 00 00 00 10 00 08 10 00 00 00 00 00
C0 00 04 00 01 02 00 00 00 05 00 09 02 10 70 30 16
D0 0B 00 91 06 10 00 31 16 00 00 00 00 00 00 00 00
100 02 00 01 13 01 00 00 00 00 00 00 00 00 00 00 00
110 00 00 00 00 01 00 00 80 00 00 00 00 00 00 00 00
120 02 00 00 81 00 00 00 00 00 00 00 00 00 00 00 00
130 05 00 01 00 00 01 00 0F 00 00 00 00 00 00 00 00
Description PCI to PCI Bridge
Location bus 0 (0x00), device 28 (0x1C), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x3B42
Revision ID 0x06
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x40
Device type Root Port of PCI-E Root Complex
Port 1
Version 2.0
Physical slot #16
Presence detect no
Link width 0x (max 1x)
PCI capability
Caps offset 0x80
PCI capability
Caps class Subsystem Vendor
Caps offset 0x90
SubVendor ID 0x8086
SubSystem ID 0x3B42
PCI capability
Caps offset 0xA0
Caps version 1.1
PCI registers
00 86 80 42 3B 04 05 10 00 06 00 04 06 08 00 81 00
10 00 00 00 00 00 00 00 00 00 01 01 00 F0 00 00 20
20 F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 00 01 02 00
40 10 80 42 01 00 80 00 00 00 00 10 00 11 4C 11 01
50 00 00 01 10 E0 0C 04 04 28 10 00 00 08 00 00 00
60 00 00 00 00 16 00 00 00 00 00 00 00 00 00 00 00
70 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 05 90 01 00 0C F0 E0 FE 50 49 00 00 00 00 00 00
90 0D A0 00 00 86 80 42 3B 00 00 00 00 00 00 00 00
A0 01 00 02 C8 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 10 00 00 02 00 00 00 00 00 11 00 00 00 00 00
E0 00 0F 00 00 06 07 08 00 31 00 00 00 00 00 00 00
100 00 00 00 00 00 00 00 00 00 00 00 00 11 00 06 00
110 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00
120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 28 (0x1C), function 5 (0x05)
Common header
Vendor ID 0x8086
Model ID 0x3B4C
Revision ID 0x06
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x00
Int. Pin 0x02
PCI capability
Caps offset 0x40
Port 6
Version 2.0
Physical slot #16
Presence detect yes
Link width 1x (max 1x)
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x90
SubVendor ID 0x8086
SubSystem ID 0x3B4C
PCI capability
Caps offset 0xA0
Caps version 1.1
PCI registers
00 86 80 4C 3B 07 05 10 00 06 00 04 06 08 00 81 00
10 00 00 00 00 00 00 00 00 00 02 02 00 E0 E0 00 20
20 F0 FF 00 00 F1 FA F1 FA 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 00 02 02 00
40 10 80 42 01 00 80 00 00 00 00 10 00 11 2C 11 06
50 40 00 11 30 60 05 2C 04 28 10 40 00 08 00 00 00
80 05 90 01 00 0C F0 E0 FE 60 49 00 00 00 00 00 00
90 0D A0 00 00 86 80 4C 3B 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 29 (0x1D), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x3B36
Revision ID 0x06
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 4 (port) 0x0000D400
Subvendor ID 0x8086
Subsystem ID 0x3B36
Int. Line 0x13
Int. Pin 0x02
PCI capability
Caps class 0x13
Caps offset 0x50
PCI registers
00 86 80 36 3B 05 00 90 02 06 00 03 0C 00 00 80 00
20 01 D4 00 00 00 00 00 00 00 00 00 00 86 80 36 3B
30 00 00 00 00 50 00 00 00 00 00 00 00 13 02 00 00
Location bus 0 (0x00), device 29 (0x1D), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x3B37
Revision ID 0x06
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000D080
Subvendor ID 0x8086
Subsystem ID 0x3B37
Int. Line 0x10
Int. Pin 0x03
PCI capability
Caps class 0x13
Caps offset 0x50
PCI registers
00 86 80 37 3B 05 00 90 02 06 00 03 0C 00 00 00 00
20 81 D0 00 00 00 00 00 00 00 00 00 00 86 80 37 3B
30 00 00 00 00 50 00 00 00 00 00 00 00 10 03 00 00
Location bus 0 (0x00), device 29 (0x1D), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x3B38
Revision ID 0x06
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000D000
Subvendor ID 0x8086
Subsystem ID 0x3B38
Int. Line 0x12
Int. Pin 0x04
PCI capability
Caps class 0x13
Caps offset 0x50
PCI registers
00 86 80 38 3B 05 00 90 02 06 00 03 0C 00 00 00 00
20 01 D0 00 00 00 00 00 00 00 00 00 00 86 80 38 3B
30 00 00 00 00 50 00 00 00 00 00 00 00 12 04 00 00
Location bus 0 (0x00), device 29 (0x1D), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x3B39
Revision ID 0x06
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000CC00
Subvendor ID 0x8086
Subsystem ID 0x3B39
Int. Line 0x17
Int. Pin 0x01
PCI capability
Caps class 0x13
Caps offset 0x50
PCI registers
00 86 80 39 3B 05 00 90 02 06 00 03 0C 00 00 00 00
20 01 CC 00 00 00 00 00 00 00 00 00 00 86 80 39 3B
30 00 00 00 00 50 00 00 00 00 00 00 00 17 01 00 00
Location bus 0 (0x00), device 29 (0x1D), function 7 (0x07)
Common header
Vendor ID 0x8086
Model ID 0x3B34
Revision ID 0x06
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFBFF0000
Subvendor ID 0x8086
Subsystem ID 0x3B34
Int. Line 0x17
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps offset 0x58
PCI capability
Caps class 0x13
Caps offset 0x98
PCI registers
00 86 80 34 3B 06 00 90 02 06 20 03 0C 00 00 00 00
10 00 00 FF FB 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 86 80 34 3B
70 01 00 DE 3F 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 20 34 5C 78
Location bus 0 (0x00), device 30 (0x1E), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2448
Revision ID 0xA6
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0xFF
Int. Pin 0x00
PCI capability
Caps offset 0x50
SubVendor ID 0x8086
SubSystem ID 0x2448
PCI registers
00 86 80 48 24 07 01 10 00 A6 01 04 06 00 00 01 00
10 00 00 00 00 00 00 00 00 00 03 03 20 F0 00 80 22
30 00 00 00 00 50 00 00 00 00 00 00 00 FF 00 02 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 12 00 10
50 0D 00 00 00 86 80 48 24 00 00 00 00 00 00 00 00
Description PCI to ISA Bridge
Location bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x3B07
Revision ID 0x06
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x8086
Subsystem ID 0x3B07
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0xE0
PCI registers
00 86 80 07 3B 07 00 10 02 06 00 01 06 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 86 80 07 3B
40 01 08 00 00 80 00 00 00 01 05 00 00 10 00 00 00
50 F8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 8A 85 83 87 D0 00 00 00 80 8B 86 8A F8 00 00 00
70 0F 00 F8 00 F8 00 F8 00 F8 00 F8 00 F8 00 F8 00
80 00 00 0D 14 01 0A FC 00 00 00 00 00 00 00 00 00
A0 08 06 20 00 49 08 06 00 00 45 00 00 00 03 00 00
D0 33 22 11 00 67 45 00 00 C0 C0 00 00 08 00 00 00
E0 09 00 10 11 91 00 E4 06 00 33 06 58 06 38 B8 02
F0 01 C0 D1 FE 00 00 00 00 87 0F 07 08 00 00 00 00
Description IDE Controller
Location bus 0 (0x00), device 31 (0x1F), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x3B2E
Revision ID 0x06
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000FF90
Address 5 (port) 0x0000FFA0
Subvendor ID 0x8086
Subsystem ID 0x3B2E
Int. Line 0x00
Int. Pin 0x02
PCI capability
Caps offset 0x70
Caps version 1.2
PCI capability
Caps class 0x13
Caps offset 0xB0
PCI registers
00 86 80 2E 3B 05 00 B0 02 06 8A 01 01 00 00 00 00
10 01 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00
20 91 FF 00 00 A1 FF 00 00 00 00 00 00 86 80 2E 3B
30 00 00 00 00 70 00 00 00 00 00 00 00 00 02 00 00
40 07 A3 00 80 00 00 00 00 01 00 01 00 00 00 00 00
50 00 00 00 00 30 10 00 00 00 00 00 00 00 00 00 00
70 01 B0 03 00 08 00 00 00 00 00 00 00 00 00 00 00
80 05 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 0F 81 83 01 00 00 00 02 59 00 00 00 00 00
B0 13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00
Description SMBus Controller
Location bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x3B30
Revision ID 0x06
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFBFEA000
Address 4 (port) 0x00000400
Subvendor ID 0x8086
Subsystem ID 0x3B30
Int. Line 0x03
Int. Pin 0x03
PCI registers
00 86 80 30 3B 03 00 80 02 06 00 05 0C 00 00 00 00
10 04 A0 FE FB 00 00 00 00 00 00 00 00 00 00 00 00
20 01 04 00 00 00 00 00 00 00 00 00 00 86 80 30 3B
30 00 00 00 00 00 00 00 00 00 00 00 00 03 03 00 00
40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 03 04 04 00 00 00 08 08 00 00 00 00 00 00 00 00
80 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 31 (0x1F), function 5 (0x05)
Common header
Vendor ID 0x8086
Model ID 0x3B2D
Revision ID 0x06
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000C800
Address 1 (port) 0x0000C480
Address 2 (port) 0x0000C400
Address 3 (port) 0x0000C080
Address 4 (port) 0x0000C000
Address 5 (port) 0x0000BC00
Subvendor ID 0x8086
Subsystem ID 0x3B2D
Int. Line 0x13
Int. Pin 0x02
PCI capability
Caps offset 0x70
Caps version 1.2
PCI capability
Caps class 0x13
Caps offset 0xB0
PCI registers
00 86 80 2D 3B 05 00 B0 02 06 85 01 01 00 00 00 00
10 01 C8 00 00 81 C4 00 00 01 C4 00 00 81 C0 00 00
20 01 C0 00 00 01 BC 00 00 00 00 00 00 86 80 2D 3B
30 00 00 00 00 70 00 00 00 00 00 00 00 13 02 00 00
40 00 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00
Description Ethernet Controller
Location bus 2 (0x02), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10EC
Model ID 0x8136
Revision ID 0x05
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x08
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000E800
Address 2 (memory) 0xFAFFF000
Address 4 (memory) 0xFAFF8000
Subvendor ID 0x10EC
Subsystem ID 0x0123
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x40
Caps version 1.2
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x70
Device type PCI-E Endpoint Device
Port 0
Version 2.0
PCI capability
Caps class MSI-X
Caps offset 0xB0
PCI capability
Caps class Virtual Product Data
Caps offset 0xD0
Caps class Advanced Error Reporting
Caps offset 0x100
Caps offset 0x140
Caps class Device Serial Number
Caps offset 0x160
PCI registers
00 EC 10 36 81 07 04 10 00 05 00 00 02 08 00 00 00
10 01 E8 00 00 00 00 00 00 0C F0 FF FA 00 00 00 00
20 0C 80 FF FA 00 00 00 00 00 00 00 00 EC 10 23 01
30 00 00 00 00 40 00 00 00 00 00 00 00 00 01 00 00
40 01 50 C3 FF 08 01 00 00 00 00 00 00 00 00 00 00
50 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
70 10 B0 02 02 C0 8C 28 00 17 20 19 00 11 7C 07 00
80 40 00 11 10 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 10 00 00 00 10 00 00 00 00 00 00 00
B0 11 D0 03 80 04 00 00 00 04 08 00 00 00 00 00 00
D0 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100 01 00 01 14 00 00 10 00 00 00 10 00 30 20 06 00
110 00 20 00 00 00 00 00 00 B4 00 00 00 00 00 00 00
Location bus 255 (0xFF), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2C62
Revision ID 0x05
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x8086
Subsystem ID 0x8086
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 86 80 62 2C 06 00 00 00 05 00 00 06 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 86 80 86 80
60 20 02 02 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 01 04 00 00 00 00 00 00
C0 0F 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 80 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 255 (0xFF), device 0 (0x00), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x2D01
Revision ID 0x05
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x8086
Subsystem ID 0x8086
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 86 80 01 2D 06 00 00 00 05 00 00 06 00 00 80 00
40 10 11 11 01 00 31 31 00 00 00 00 00 00 12 00 00
50 01 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 E0 BB 00 00 00 00 00 0C E0 FF FF 00 00 00
80 83 0B 00 00 C2 0F 00 00 83 23 00 00 82 23 00 00
90 82 23 00 00 82 23 00 00 82 23 00 00 82 23 00 00
Location bus 255 (0xFF), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2D10
Revision ID 0x05
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x8086
Subsystem ID 0x8086
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 86 80 10 2D 06 00 00 00 05 00 00 06 00 00 80 00
40 00 01 8F 08 00 00 00 00 00 00 14 00 00 00 00 00
50 00 00 00 A6 00 00 00 00 55 45 06 00 00 00 00 00
C0 00 00 5F 00 85 06 00 00 00 00 00 F3 00 00 00 00
D0 01 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 255 (0xFF), device 2 (0x02), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x2D11
Revision ID 0x05
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x8086
Subsystem ID 0x8086
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 86 80 11 2D 06 00 00 00 05 00 00 06 00 00 80 00
40 09 00 FF F0 01 00 80 0B 00 00 10 00 73 02 00 00
50 12 01 0C 12 12 00 00 00 01 00 00 00 01 00 00 00
60 00 00 00 00 00 00 00 00 00 51 C3 10 A0 A0 40 00
70 00 00 00 00 FF FF 0F 80 00 00 00 00 FF FF 0F 00
80 03 0F 0F 07 00 00 00 00 01 00 00 00 01 00 0F 0F
90 82 00 00 00 02 02 01 00 08 08 88 08 02 05 00 00
A0 00 AE 00 00 03 2C 1D 00 84 00 00 06 02 00 00 00
B0 77 15 AE 4D 00 00 00 00 00 00 00 00 01 00 00 00
D0 09 0C 09 0C 00 00 00 00 00 00 00 00 03 00 08 00
E0 00 00 02 00 00 00 40 00 00 00 82 24 00 00 00 00
F0 00 00 00 00 42 01 00 00 00 00 00 00 00 00 00 00
Location bus 255 (0xFF), device 2 (0x02), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x2D12
Revision ID 0x05
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x8086
Subsystem ID 0x8086
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 86 80 12 2D 06 00 00 00 05 00 00 06 00 00 80 00
Location bus 255 (0xFF), device 2 (0x02), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x2D13
Revision ID 0x05
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x8086
Subsystem ID 0x8086
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 86 80 13 2D 06 00 00 00 05 00 00 06 00 00 80 00
DMI
SMBIOS Version 2.6
DMI BIOS
vendor American Megatrends Inc.
version 080015
date 07/07/2015
ROM size 1024 KB
DMI System Information
manufacturer To Be Filled By O.E.M.
product To Be Filled By O.E.M.
version To Be Filled By O.E.M.
serial To Be Filled By O.E.M.
UUID {03000200-0400-0500-0006-000700080009}
SKU To Be Filled By O.E.M.
family To Be Filled By O.E.M.
DMI Baseboard
vendor INTEL
model To be filled by O.E.M.
revision To be filled by O.E.M.
serial To be filled by O.E.M.
DMI System Enclosure
chassis type Desktop
chassis serial To Be Filled By O.E.M.
DMI Processor
manufacturer Intel
model Intel(R) Core(TM) i5 CPU M 540 @ 2.53GHz
clock speed 2533.0 MHz
FSB speed 133.0 MHz
multiplier 19.0x
DMI Memory Controller
correction 64-bit ECC
Max module size 4096 MBytes
DMI Memory Module
designation DIMM0
size 4096 MBytes (double bank)
DMI Memory Module
designation DIMM1
DMI Memory Module
designation DIMM2
DMI Memory Module
designation DIMM3
DMI Port Connector
designation J1A1 (internal)
designation PS2Mouse (external)
port type Mouse Port
connector PS/2
DMI Port Connector
designation Keyboard (external)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation J2A2 (internal)
designation USB1 (external)
port type USB
connector Access Bus (USB)
DMI Port Connector
designation USB2 (external)
port type USB
DMI Port Connector
designation J4A1 (internal)
designation LPT 1 (external)
port type Parallel Port ECP/EPP
connector DB-25 male
DMI Port Connector
designation J2A1 (internal)
designation COM A (external)
port type Serial Port 16550A
connector DB-9 male
DMI Port Connector
designation J6A1 (internal)
designation Audio Mic In (external)
port type Audio Port
connector Mini Jack (headphones)
DMI Port Connector
designation Audio Line In (external)
DMI Port Connector
designation J6B1 - AUX IN (internal)
connector On Board Sound Input From CD-ROM
DMI Port Connector
designation J6B2 - CDIN (internal)
DMI Port Connector
designation J6J2 - PRI IDE (internal)
connector On Board IDE
DMI Port Connector
designation J6J1 - SEC IDE (internal)
DMI Port Connector
designation J4J1 - FLOPPY (internal)
connector On Board Floppy
DMI Port Connector
designation J9H1 - FRONT PNL (internal)
connector 9 Pin Dual Inline (pin 10 cut)
DMI Port Connector
designation J1B1 - CHASSIS REAR FAN (internal)
DMI Port Connector
designation J2F1 - CPU FAN (internal)
DMI Port Connector
designation J8B4 - FRONT FAN (internal)
DMI Port Connector
designation J9G2 - FNT USB (internal)
DMI Port Connector
designation J6C3 - FP AUD (internal)
DMI Port Connector
designation J9G1 - CONFIG (internal)
DMI Port Connector
designation J8C1 - SCSI LED (internal)
DMI Port Connector
designation J9J2 - INTRUDER (internal)
DMI Port Connector
designation J9G4 - ITP (internal)
DMI Port Connector
designation J2H1 - MAIN POWER (internal)
DMI Extension Slot
designation AGP
type AGP 4x
width 32 bits
populated yes
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 4 GB
max# of devices 4
DMI Memory Device
designation DIMM0
format DIMM
type SDRAM
total width 64 bits
data width 64 bits
size 4 GB
DMI Memory Device
designation DIMM1
format DIMM
type unknown
DMI Memory Device
designation DIMM2
format DIMM
type SDRAM
total width 64 bits
data width 64 bits
size 4 GB
DMI Memory Device
designation DIMM3
format DIMM
type unknown
Storage
Drive 0
Name CT1000MX500SSD1
Revision M3CR023
Serial 2005265F4ACA
Capacity 931.5 GB
Type Fixed, SSD
Bus Type ATA (3)
Features SMART, TRIM
Volume c:\, 439.5 GBytes (88.1 percent available)
Volume d:\, 492.1 GBytes (92.6 percent available)
USB Devices
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x046D, product=0xC534
Graphics
Number of adapters 1
Graphic APIs
API D3D
API Intel I/O
Display Adapters
Display adapter 0
ID 0x4000000
Name Intel(R) HD Graphics
Board Manufacturer Intel Corporation
PCI device bus 0 (0x0), device 2 (0x2), function 0 (0x0)
Vendor ID 0x8086 (0x8086)
Model ID 0x0046 (0x0046)
Revision ID 0x18
Performance Level 0
Win32_VideoController AdapterRAM = 0xEDB8E800 (3988318208)
Win32_VideoController DriverVersion = 8.15.10.2900
Win32_VideoController DriverDate = 11/26/2012
Monitor 0
Model 20W ()
ID HDT2000
Serial
Manufacturing Date Week 22, Year 2012
Size 17.1 inches
Max Resolution 1600 x 900 @ 60 Hz
Horizontal Freq. Range 0-0 kHz
Vertical Freq. Range 0-0 Hz
Max Pixel Clock 0 MHz
Gamma Factor 2.2
Software
Windows Version Microsoft Windows 10 (10.0) Professional 64-bit (Build 18363)
DirectX Version 12.0
Register Spaces
Register space PCI
Register space PCI #2
Register space SMBus, base address = 0x0400
Register space LPC, base address = 0x02E
it is what i see
is there no listed in cpuz > mainboard > manufacture and model?
or in speccy > motherboard
is there a photo of the motherboard?
