Help identify RAM MHz
selvan777
24
I recently bought RAM for an Acer Aspire 5251 described as "8GB KIT DDR3 1066 MHZ PC3 8500 256x8 (2x4GB) SODIMM" but need help determining what it actually is after installing.
My specs call for:
Dual-channel DDR3 SDRAM support: Up to 4 GB of DDR3 1066 MHz memory, upgradable to 8 GB using three soDIMM modules(for 64-bit OS)
(I think three sodimms is an error, I only have two slots)
Results from Geekbench 2.2.3:
Cores 1 Memory 8.00 GB DDR3 SDRAM 541MHz
(is this roughly 2x541)
and from Sandra Lite 2012:
8GB DDR3 SO-DIMM 2x 533MHz (1GHz) 2x V01D3SF4GB26826813 4GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5)
(is this roughly 2x533, what's with the DDR3-1334)
Thanks a bunch.
i would use this...
i would use this free program to check your internals it's called speccy
http://www.piriform.com/speccy
RAM
Memory slots
Total memory slots 2
Used memory slots 2
Free memory slots 0
Memory
Type DDR3
Size 8192 MBytes
Channels # Dual
DRAM Frequency 532.0 MHz
CAS# Latency (CL) 7 clocks
RAS# to CAS# Delay (tRCD) 7 clocks
RAS# Precharge (tRP) 7 clocks
Cycle Time (tRAS) 20 clocks
Bank Cycle Time (tRC) 27 clocks
Command Rate (CR) 1T
Physical Memory
Memory Usage 24 %
Total Physical 7.75 GB
Available Physical 5.85 GB
Total Virtual 15 GB
Available Virtual 13 GB
SPD
Number Of SPD Modules 2
Slot #1
Slot #2
Thanks, I got it and above is the results from Speccy, it only says 532 MHz which still makes me wonder.
Never the less, I see the answer to my question is already there in Sandra (8GB DDR3 SO-DIMM 2x 533MHz), it's all good than, thanks again.
