Hi all, I have a 1440p, 144hz viewsonic monitor that's served me well for a few years now. A couple of days ago during normal video gaming it started to show flickering vertical lines rapidly, appearing in blocks up and down the screen, and it started to go blank for a few seconds (I could still hear audio through my separate speakers) a few times. Immediately I found that reducing the refresh rate down from 144hz to 60hz though obviously not ideal.
I turned off the computer, unplugged everything and cleaned it out, then re-seated both the GPU and RAM components and re-booted, still flickering. Next I ran the windows memory diagnostic to double check the RAM and it found no issue. I rebooted windows into safe mode and performed a clean installation of the latest nvidia drivers and that didn't solve it either. I also ran heaven's benchmark and my graphics card performed as expected, sans the flickering, vram correctly detected, no artifacts, high frame rates good temp. I ordered a new displayport cable, swapped it in and that hasn't solved the issue either, and I do not have another 144hz device to connect to unfortunately.
One oddity occurred the day after the flickering started, during gameplay at 60hz, with chrome running the the background, the monitor started to black out for a few seconds as before. After a few times, windows crashed, citing "Memory management" which is what prompted me to double check the ram with memory diagnostic tool, I then performed the clean GPU driver install afterwards. I have not seen any more blackouts at 60hz after the clean driver install, unsure if related to the issue since nothing so far has solved the monitor flickering at higher refresh rates
So my question is, does it sound like either my monitor, or my GPU is suddenly on the fritz? I'm really hoping it's not the card as that would be much harder to replace of course, any help would be appreciated.
Here is my setup;
Windows 10 Home
MSI B450 GAMING PRO CARBON AC (Socket AM4) DDR4 ATX Motherboard
AMD Ryzen 5 3600 6-Core Processor 3.60 GHz
Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz
GeForce RTX 2070 Super
650W EVGA SuperNOVA 650 G1+, Full Modular, 80PLUS Gold
Here is my setup;
Windows 10 Home
