Help identifying retail name of RS-CS-SS audio connectors.
Valchrist
Commendable
Sep 23, 2016
I have been to several computer and audio shops asking about a cs-ss-rs connector for 5.1 audio from my PC to my receiver. I described the cables and their function in detail. Nobody seemed to know what I was talking about Is there a specific name I can ask for? Are they generally difficult to find? No electronics shop in town seems to carry them.
Thank you.
My understanding was must have the three connections, CS out, SS out and RS out, from my PC, which connect to the RS in, CS in and SS in of my receiver.
I thought I had to go to the shop and get cables of that description, CS, SS, RS, and figured they would likely be colour coded.
I was wrong. It took a couple minutes of puzzling out your comment before I got what you were saying. Each of those goes in to two stereo receivers each for side, center/sub and front. Thanks a ton.
Thanks for clarifying.
Optical wasn't an option, as there's no port on the PC.
Latest posts
