Hey everybody.
Im relatively new to overclocking and this is doing my head in!
My specs are:
G3258
Hyper X fury 1866 8GB
Gigabyte Z97p-D3
EVGA SSC 960
EVGA 500w 80+
1tb WD Blue
Hyper 212 Evo
I have been fiddling about with overclocks and have got it relatively stable at 4.4 or so i thought...
I run prime95 and after 4-5 minutes on blend test i get an ''uncorrectable hardware error'' BSOD.
I have checked the list of errors and what needs to be adjusted but I cant find QTI/PTT settings on my mobo.
It also says to check the Vcore so im not sure which one to mess with as this is the only error I have encountered.
I have the Vcore at 1.305v and multiplier at x44.
The only other thing I have changed is the Uncore to 4.3.
Is there anything else I should take into consideration such as Load Line calibration etc?
Everything is running cool under load at stock and also when i was running Prime my temps were not at any level to be problematic at all.
They were averaging 37 and maxing at 50.
Im pulling my hair out!!!
Thanks in advance
My specs are:
G3258
Gigabyte Z97p-D3
EVGA SSC 960
EVGA 500w 80+
1tb WD Blue
Hyper 212 Evo
Thanks in advance
