Help. Im frustrated with all these huge variety of hardware
Aug 22, 2018
11
Hello community ))) I need your help.
- Approximate Purchase Date: i think one month to get main parts
- Budget Range: cheaper is better ~1k-1.5k$
- System Usage: planning to jump into Architecture Visualization 3DMax (Vray, Corona), Blender (GPU render: Nvidia's CUDA), After Effects (same: Nvidia), Photoshop and maybe Unreal Engine for 3D walkthrough.
- Are you buying a monitor: No
- Parts to Upgrade: NEW
- OS: Windows 10 - thanks velocityg4
- Preferred Website(s) for Parts: Russian website https://www.dns-shop.ru/catalog/382ca5fe3ba97fd7/osnovnye-komplektuyushhie/
68 RUB~1 $
- Parts Preferences: by brand or type (e.g.: I would like to upgrade to Intel CPU)
- Overclocking: No / Maybe
- SLI or Crossfire: No / Maybe
-Additional Comments:
CPU:
Im planning to get into AMD way, so want to buy Ryzen 7 2700(X)
Ryzen 7 2700 BOX ~351$
Ryzen 7 2700X BOX ~403$
I heard that 2700X = 2700(overclocked) + Better Fan(new fan ->OEM 10$ difference)
But dont sure that i want to evrclock it (if it is easy, why not)
MOBO: Standart ATX
mobo x470 ??? there tons of mobos on the market >.<
Lurking around i found comment of a member VALTO.MAKELA about ASUS mobos
Crosshair VII, Asus strix x470-f gaming, Asus x470 prime pro, MSI x470 gaming plus.
ASUS ROG CROSSHAIR VII HERO = Out Of Stock (need to order)
ASUS ROG STRIX X470-F GAMING = 254$
ASUS PRIME X470-PRO = 220$
MSI X470 GAMING M7 AC = 254$
MSI X470 GAMING PRO = 165$
It will be great to upgrade in future with M.2 SSD (need smthng with heat sink for that)
GPU:
Looking for 8GB card. BUT. 1070 and 1070Ti and 1080 they are all 8GB. But Ti ~50-100$ more expensive than non-Ti:
Asus GeForce GTX 1070 DUAL [DUAL-GTX1070-O8G] = 487$
MSI GeForce GTX 1070 ARMOR OC [GTX 1070 ARMOR 8G OC] = 490$
Palit GeForce GTX 1070 SUPER JETSTREAM [NE51070S15P2-1041J] = 520$
Palit GeForce GTX 1070 Ti SUPER JETSTREAM [NE5107TP15P2-1041J] = 571$
Zotac GeForce GTX 1070 AMP! Core Extreme ZT-P10700N-10P = 571$
Also, explain me difference between Ti and non-Ti cards. Is it real to feel the difference in render of scenes in 3D????
I want smthng silent and cool. Heard good reviews about palit cards jetstream series (not dual)
RAM:
2x8GB (at the beginning) need smthng to connect all these ^^^ devices to work together as In and Yan )))
PSU:
I know nothing about it, depends on main parts configuration power
Thanks to everyone who will take a part in dat discussion. Cheers
If you want Windows 7 you are going to need an old CPU (AMD FX or Intel Skylake and older). There are patches and hacks to get it working. Do you really want your work computer to rely on unofficial patches and hacks to function? You can always turn off telemetry and edit the group policy to disable automatic updates (Windows 10 Pro required to avoid the registry). Otherwise there isn't a huge difference between Windows 7 and 10.
Aug 22, 2018
11
Oh gosh... i didnt know that Ryzen not support < Win10 o_O
Ok, then it will be Win10 (have experience with dat OS)
