(HELP) Im Having 60/40 fps GTA V with my GTX 1070
Hector_7
Commendable
Apr 10, 2016
6
UserBenchmarks: Game 103%, Desk
81%, Work 56%
CPU: Intel Core i7-6700K - 90%
GPU: Nvidia GTX 1070 - 130.6%
SSD: Kingston SSDNow UV400 120GB - 57.1%
HDD: Toshiba MQ01ABD075 750GB - 58.1%
HDD: Seagate Barracuda 7200.14 500GB - 65.9%
RAM: Team Team-Elite-2400 1x8GB - 43.7%
MBD: MSI Z170A TOMAHAWK (MS-7970)
What you see above is my PC specs
My Graphic cards is a msi gaming X
I having 60 fps with random 40 fps spikes in 1080p.
My PSU is 750Watts 2 years old. (Tacens mars mp700)
Windows 10
temps on GPU looks OK 40 / 50 celsius deegrees
I tried to:
  • Reinstall windows
    Reinstall drivers.
The drawing distance (1-10) maxed at 10 and 8x MSAA are the heaviest hitters, go down to 4x MSAA and 5 out of 10 drawing distance (in advanced settings). I just went back and forth on the two in my GTA5 and couldn't see a difference excluding FPS doubling.
Also the combo of Long Shadows (advanced settings) and Very High Shadows make a very taxing combined shadow rendering, turn Long Shadows off and Shadows to High instead of Very High if you need more FPS.
Your RAM could also be causing some slight FPS lag when the game needs to load things quickly (driving/flying etc.). But before buying new hardware i would recommend trying the tips @JUICEhunter mentioned. Also lower the Population setting, thats an FPS eater too.
