Hi There!
Thanks so much for your great forum and for the huge help
I am a visualiser and I need to build my 3d rendering station. (Rhino/SketchUp/3dsMax)
I was thinking on something like:
MB: MSI x99s-SLI
CPU: i7 5820k
RAM: 16gb ddr4 corsair (4x4)
GPU: Quadro K2200 4gb
SSD: 256gb crucial
HD: 2tb Barracuda
POWER: 650W
My concern is that with the same budget I could go for a "older" CPU and increase to 32gb memory ddr3...Could you please tell me if the components I have listed are a good solution or if I should go for a different system with a £1300 budget?
Any suggestion is more than welcome!!
Thanks a lot
Ciao!
Ciao!!
MB: MSI x99s-SLI
CPU: i7 5820k
SSD: 256gb crucial
HD: 2tb Barracuda
POWER: 650W
Thanks a lot
Ciao!
Ciao!!
