Hi,
I want to build a PC that will be running games in 4k on ultra settings with at least 60 FPS in most of the games.
This is what I've come up with so far.
CPU : Intel i7-13700K
Motherboard: ASUS PRIME Z790-A WIFI
GPU: Palit GeForce RTX 4080 GameRock OC 16GB
RAM: Kingston FURY 32GB (2x16GB) 6000MHz CL32 Renegade Silver
SSD: Kingston 2TB M.2 PCIe Gen4 NVMe KC3000 and WD SN850X 2TB
Cooler: Corsair iCUE H170i ELITE CAPELLIX 3x140mm
Case: Fractal Design Define 7 XL Black TG Light Tint
PSU: be quiet! Straight Power 11 1000W 80 Plus Platinum
I am debating whether to change Case and/or cooler for something else.
Will this build be okay? Can you suggest if I should change something in my build? I would appreciate it.
