HELP IN BUYING CARD
saruavgamer
Hi,Ihave the folloeing configuration-
Intel Core 2 Duo E7500 2.93 GHz
Intel DG41TY Motherboard
640GB HDD (320+320)
650W SMPS
I am planning to buy an XFX Graphics Card.But which one will I take?
XFX Gefoce 9800GT 1GB
OR
XFX GEFORCE 9800 GTX 1GB
PLEASE SUGGEST ME!
You will get better performance from the 9800GTX, a 9800GTX+ would be a bit higher performance with the 9800GT being on the bottom.
9800GTX+ > 9800GTX > 9800GT
As long as you don't have to pay a much higher price, go with the better performing card.
itisravi
89
If you are not a Nvidia fan, i would suggest you to look at ATI 5750 512MB. It performs better than any of these cards, consumes much less power, has DX11 Support, all at a similar price.
