Which GPU is better? INNO3D Nvidia Geforce GT 730 2GB GDDR5 64-BIT @PHP 3050/$65 vs. HIS AMD Radeon R7 240 2GB GDDR5 128-BIT @PHP 2850/$61
Note: They're from different shops.
This will be mainly used for gaming. Even on low settings at 1280x1024. It just have to be playable. I prefer the 2GB ones because I want to try Tom Clancy's: The Division on low settings.
How do I choose GPU?
Which HDD is better? Western Digital WD10EZEX 1TB 7200RPM SATA III 64MB Cache @PHP 2450/$52 vs. Seagate ST1000DM003 1TB 7200RPM SATA III 64MB Cache @PHP 2550/$55 vs. Toshiba DT01ACA100 1TB 7200RPM SATA III 32MB Cache(This one is the cheapest) @PHP 2300/$49
Does Cache affect HDD performance?
Please don't suggest parts with higher prices. I'm on a really tight budget. I'm only at 16 years of age and prices are quite expensive here in the Philippines.
My PC Specs:
Processor: Intel Celeron G1820 2.7GHz LGA 1150 @PHP 1750/$37
Motherboard: Biostar H81MHV3 LGA 1150 @PHP 2100/$45
RAM: Kingston 2GB 1333MHz @PHP 620/$13
GPU: Palit Nvidia Geforce 210 1GB DDR3 64-BIT(Bought this 3 years ago) @PHP 1650/$35
I'll overclock this one to its maximum and use it until it burns itself.
PSU: None yet. Planning to buy a generic one. How many watts do I need? I have seen a 600w @PHP 680/$15
Monitor: HP Compaq LE1711 17" LCD VGA 1280x1024@60Hz(Pre-Owned)(Bought this on a very cheap price last year) @PHP 1850/$40
Operating System: Windows 10 64-BIT PRO
Optical Disk: None yet. Planning to buy a generic DVD Burner. I have seen a cheap one @PHP 790/$17
Thanks in advance!
My PC Specs:
Thanks in advance!
