Greetings
I am in need of some assistance in choosing between two different prebuilt PCs.
The PC is for a friend of mine who wants it for playing FPS/Racing games and he has a price range of roughly 2,400 USD. I have landed on two different ones which both seem to be solid. I do have some concerns about the graphic card and power supply. Some say the graphics card can overheat because of some plastic component, while others say it is not an issue at all. The power supply seems a bit low, but when I use the PCPartPicker it does not seem to use nearly as much as the power supply. The other power supply I was looking at was: ASUS TUF GAMING 750B, 750W PSU.
Here are the two PCs:
Both at roughly the same price, 2,400USD.
Thank you for helping out!
- Phanteks Eclipse G360A Mid Tower
- MSI GeForce RTX 4070 VENTUS 2X OC
- AMD Ryzen 7 7800X3D CPU Tray
- Cooler Master ML240L V2 RGB CPU Cooler
- Kingston FURY Beast RGB DDR5 6000MHz 32GB
- Kingston FURY Renegade PCIe M.2 NVME SSD 2TB
- WD BLACK SN770 NVMe SSD 1TB
- ASUS TUF Gaming B650-PLUS WIFI
- Cooler Master MWE Gold 650 V2 PSU
- Windows 11 Home
- Intel Core i5-13600K CPU
- Pure Rock 2 Black CPU Cooler
- Kingston FURY Beast DDR5 6000MHz 32GB
- MSI MAG B760 Tomahawk WiFi
- Windows 11 Home
