Hello. I bought a used PC from Craigslist. It's a tower with an ASUS motherboard. But I have no idea of the tower model number because I have no documentation/specs for this PC.
The tower is different from other towers because it doesn't have screws for mounting brackets like this (https://drive.google.com/file/d/1Q03TEwbMUgpeW9Z72CFnXS5auhvWI0Zv/view?usp=sharing). These are the usual mounting brackets on other towers that I have.
This tower doesn't have screwholes but instead spaces for plastic clips; this pic shows the inside of the tower (https://drive.google.com/open?id=1QbuG1tgpDj6XQ4Z_y8Is0iXW6bJ2qj-b).
Notice that the tower has these circular frames that allow you to insert plastic clips. But it doesn't have any screwholes for any mounting brackets.
The PC comes with a pair of plastic clips that slide between the circular holes (https://drive.google.com/open?id=1E8H7HqRpxBpR4Q9BOPcQGs-BrJL_R-dL)
The clips are 5 1/2" in length, 1 7/8" in width, and 3/16" thick.
I need to buy more of these clips because I want to add more peripherals.
I can't identify these clips though. I went to Central Computing, Fry's Electronics, and asked a PC used parts seller about these but none of them could identify these plastic clips.
Can anyone help me identify these parts so I can start searching the Internet to buy them?
Thanks.
Thanks.
