Help in selecting & building a new system
ibaadnaqvi
16
Hello as I have limited budget so i would like to have your opinions for selecting components for my system.
I would like to go for:
1- Motherboard: MSI Computer Corp. ATX DDR3 | ASUS Z297-A | Gigabyte Z97X Gaming 3. Please tell me which one is good as later i would be running core i5 4th or amd 8350 fx processor
2- ASUS R9270-DC2OC-2GD5 Radeon R9 270 2GB 256-bit GDDR5 PCI Express 3.0 CrossFireX Support Video Card
3- Also please recommend which liquid cooler will be compatible with these because Corsair H100i liquid cooler is not compatible with ASUS Z297-A
4- Which Casing should I go for ?
5- Which RAM should I select & power supply?
Would be waiting for your great replies
thanks,
The H100i is compatible with the ASUS Z97-A. However the Cooler Master Nepton 240M is better.
You can go with a air cooler like the Enermax ETS-T40 to save cost but will perform well.
There is a Gigabyte R9 270X available for about the same price as the ASUS R9 270 and will perform better.
I didn't include a hardrive, if that should be in the build as well we'll have to cut costs here and there.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($219.99 @ Newegg)
CPU Cooler: Cooler Master Seidon 240M 86.2 CFM Liquid CPU Cooler ($74.99 @ Newegg)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard ($119.99 @ Newegg)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($54.99 @ Newegg)
Video Card: Gigabyte Radeon R9 270X 2GB WINDFORCE Video Card ($137.99 @ Newegg)
Case: Thermaltake Versa H34 ATX Mid Tower Case ($59.99 @ Amazon)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply ($49.99 @ NCIX US)
Total: $687.93
Generated by PCPartPicker 2014-12-06 14:37 EST-0500
thank you soo much your information was very helpful.. And one more think ASUS motherboard is better then these MSI Computer Corp. ATX DDR3 | ASUS Z297-A | Gigabyte Z97X Gaming 3 ? And for the graphic card regarding Gigabyte Radeon R9 270X 2GB WINDFORCE Video Card reviews weren't as fruitful as ASUS R9 270
The ASUS one has more features and has a better quality. If you wanna safe costs, you can get a lower end motherboard.
The R9 270X is better than the R9 270, I think you're confused.
http://www.kitguru.net/components/graphic-cards/zardon/gigabyte-r9-270x-windforce-oc-review/
