Help in setting up multiple monitors
Jun 30, 2018
I am struggling to setup multi-monitor setup, no other ports work besides the one hdmi port on my GPU the other 3 DP slots on it i guess dont work either, the Hdmi slot on my motherboard dosent work either
Mother board - Z170-HD3P
GPU - R9 390X GIGABYTE
CPU - I5 6600K
First you need to find out if multi-monitor is supported in your BIOS. Without multi-monitor enabled, the motherboard video out ports are deactivated when a graphics card is installed. Also note not all motherboard BIOS have multi-monitor.
So find the option to enable Multi-monitor first. The motherboard manual should have instructions on enabling and setting up the monitors. You can download the monitor here.
https://www.gigabyte.com/Motherboard/GA-Z170-HD3P-rev-10#support-manual
