Hi everyone,
I am doing some research on upgrading my computer since it is more then 7 years old, even though it works quite well it is still strugling with running the newest games which is what i am using it for (cod + bf2042)
so i will try to do it as instructed but i don't have answers to some of the questions. here we go:
Approximate Purchase Date: about 3 months period.
Budget Range: don't have real budget, at some places will put the extra cash for improving and future proofing but generally would like to do more of a mid budget range.
System Usage from Most to Least Important: gaming.
Are you buying a monitor: no
Parts to Upgrade: CPU (have i7 3770K) and mobo (as i have to), RAM, and new SSD as well. also cooling might be needed. oh, and i want a better cooling Case.
Do you need to buy OS: No
Preferred Website(s) for Parts: don't have one
Parts Preferences: Intel for the CPU (want the i7 12700k), and think i will prefer one of asus\msi\gigabyte mobo's, but open for suggestions if there is a big advantage for others.
Overclocking: probably not, but optional.
SLI or Crossfire: Nope
Additional Comments: want it to be well built as for the rig i use now i can still play most of the games and all i upgraded till now was the GPU once (RTX 2060 Super). want it to be cool (temp wise) and quiet. don't need a wifi as i connect via LAN. don't know if i want the DDR5 or to settle for DDR4 (think probably is enough). want a lot of USB ports
, and air cooling (as i have no experience with water cooling at all)
And Most Importantly, Why Are You Upgrading: improving gaming experience.
thats all :O
I will upload the specs of my computer later on.
Thanks in advance!
, and air cooling (as i have no experience with water cooling at all)And Most Importantly, Why Are You Upgrading: improving gaming experience.
thats all :O
Thanks in advance!
