Hello everybody
I put together a new build and wanted to monitor the temperatures to make sure everything is constructed well. I started using HWmonitor and saw the TMPIN0 temperature from the motherboard sensors is constantly at 115 celsius.
Because all other temperatures are good, I double checked with HWinfo and see the folllowing:
CPU around 33
Motherboard 28-31
Temp3 108
Temp4106
Temp5 106
Temp6 115
Screenshot:
In light of all other temps being normal and the fact that these high temperatures are there immediately after startup I do not believe they are correct.
Anyone have ideas how to troubleshoot this? I also do not have a clue what these temperature sensors are.
Thanks in advance for your help.
My rig:
Intel Core i5 4690K @ 3.5 Ghz (not yet overclocked)
16 GB Ram
Asus Z97i Plus Mainboard
Gainward GTX 980 Phantom
Windows 8.1 Update
CPU around 33
Motherboard 28-31
Temp3 108
Temp4106
Temp5 106
Temp6 115
Screenshot:
My rig:
16 GB Ram
Windows 8.1 Update
