Question Help installing Chasis ARGB fans
boogie_1987
48
I hate how vague instructions are for something that can potentially damage your components if installed wrong.
I have a Cooler Master TD500 mesh. The 3 front ARGB fans have their 3 RGB cables plugged to a cable that ends on a single cable. That goes to my B450 Aorus pro wifi 3 ping RGB header. Which I suppose is the one on the picture.
How am I supposed to plug this thing?, in which direction?, Is that even the correct header?.
My H500 had a 4 pin cable and I had it plugged into the 12v G R B W header. The triangle was lined up with the 12v pin.
I will include a photo of the user manual. I don't understand what those numbers and drawings mean.
Thank you
View: https://imgur.com/a/rCbjFXu
looks pretty well outlined.
the two branches on the left of the image are for connecting to two different types of motherboard aRGB headers.
top; labeled (Gigabyte)
bottom; labeled (ASUS,...)
whichever type of these two headers you have available on the motherboard would be used.
top; for what appears to be a proprietary Gigabyte header
bottom; for standard aRGB headers
check your motherboard manual for available headers.
there will be an image with detailed description.
boogie_1987
48
Check the other photos please. My problem is that I don't know in which direction I should plug the RGB cable, please check the other photos.
boogie_1987
48
for what?
the cables in the image and the headers on the motherboard are labeled with placement arrows included.
Hi.
That's the problem, I don't understand the images in my Motherboard's manual. That's why I need help. I included them so someone can help me understand them. There are no placement arrows in my motherboard, see the image please.
The cable has 3 holes so I suppose it goes to those 3 pin headers. My 3 fans are 12v. Does the triangle have to line up with the white square below to get 12v? Or what does that mean?, Is that even the correct header?. Should I use the "12v G R B W" connector with the triangle aligned with the 12v pin?.
Thanks.
