D DKH Honorable Oct 16, 2013 8 0 10,510 Mar 13, 2015 #1 So I just recently bought an 850 Pro SSD and it did not include a SATA to USB Adapter Cable. Do I need one to clone my desktop HDD to the SSD? or is the cable just for laptop users? Can I use my spare SATA cable?
USAFRet Titan Moderator Mar 16, 2013 179,849 22,157 184,590 Mar 13, 2015 #2 Yes, you can use your existing SATA cable. What are you wanting to do? Clone from the old drive to the new drive? Is your current used space under 200GB? Upvote 0 Downvote
D DKH Honorable Oct 16, 2013 8 0 10,510 Mar 13, 2015 #3 USAFRet : Yes, you can use your existing SATA cable. What are you wanting to do? Clone from the old drive to the new drive? Is your current used space under 200GB? Yea I want to clone it HDD to SSD and it s 215GB. Would it still let me clone? Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,849 22,157 184,590 Mar 13, 2015 #4 DKH : USAFRet : Yes, you can use your existing SATA cable. What are you wanting to do? Clone from the old drive to the new drive? Is your current used space under 200GB? Yea I want to clone it HDD to SSD and it s 215GB. Would it still let me clone? I don't think so. The Samsung software will probably choke. You can try it, and see what it says.... Upvote 0 Downvote
