Help!!! Is Deepcool Aurora Da500 80+ Bronze a good power supply for my system??
mechHead631
Commendable
Jun 5, 2016
23
My PC specs(going to assmeble, not yet purchased. For budget gaming at 1366x768):
CPU: Pentium skylake g4400 3.3 ghz
GPU: Zotac gtx 950 amp! edition
Motheboard: Msi h110m pro-vd
RAM: kingston hyperx 2133 mhz ddr4 8gb
HDD: wd 1tb 7200rpm blue
CASE: deepcool tesseract
PSU: Please tell is Deepcool Da500 psu good. My other option is antec vp450p but it is not 80+ certified. Please suggest the best.Thanks in advance to everyone who replies to this thread. :)
Also there is only one review of Deepcool psu that I could find.
Link: http://www.eteknix.com/deep-cool-da500-aurora-500w-power-supply-review/
So is antec vp450p a good option?? Because in India seasonic PSUs have ridiculously high price and they are out of my budget. So should I go with antec??
Bro which psu u got? I am with specs just confused about the psu... Seasonics are so high in our Country as you said...... Please tell me which psu u choose and how is it running... I was thinking of the Deepcool Aurora da500 or thermaltale tr2 500w power supplys.... Which are both 3.6k. Thanks in advance :)
What is your budget?? Go with antec power supplies. They are good value for money in India. Corsair VS series are ONLY good for office use computers. Go with antec VP series with P suffix
Bro I am still waiting to get a job. I am yet to buy and assemble my PC. :??:😀 If you haven't already bought your components go with i3 6100 and rx 460 4gb. rx 460 4gb is only 12500 with vulkan and better dx 12 support. Best is SAPPHIRE NITRO rx 460. Don't go with pentium. Go with at least i3. At least it has hyperthreading. If you are gaming at 1366x768 or 900p then rx 460 is best option.
What are you using bro?? And I have a very bad experience with those thrash vs series psu... Under 4k is my budget...
Bro I am still waiting to get a job. I am yet to buy and assemble my PC. :??: 😀 If you haven't already bought your components go with i3 6100 and rx 460 4gb. rx 460 4gb is only 12500 with vulkan and better dx 12 support. Best is SAPPHIRE NITRO rx 460. Don't go with pentium. Go with at least i3. At least it has hyperthreading. If you are gaming at 1366x768 or 900p then rx 460 is best option. For PSU go with Antec VP550P. If you are lucky you can find one for 3.5k on local stores. On mdcomputers.in it costs 3.7 k and on amazon.in it costs about 4100 rs.
Here is the list of PSU tiers. Antec VP series is good mid range PSU series. Much better than Corsair VS series
https://www.reddit.com/r/pcmasterrace/comments/3q2htw/updated_psu_tier_list/
All the best for your build.:)
